How Do I Fasten And Screw Or Bolt To Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 11:30 AM   #1
DaLaiMan2000
how do I fasten and screw or bolt to concrete
Problem: I want to drill a hole into the concrete slab. (Done)
Now, what I need... is a way to fasten down a 2" Hitching Ring (Plate Type-zinc finish)
What kind of screws? (If a special kind)
Any info of any kind will be helpful. TY!
laimana2000 is offline   Reply With Quote
Old 01-28-2009, 11:44 AM   #2
Are you talking about something like this?
http://www.horsetackinternational.co...-fastener.html
jerryh3 is offline   Reply With Quote
Old 01-28-2009, 11:50 AM   #3
Rewards Points: 1,910
tapcon screws should work. You'll need a hammerdrill to drill the holes.
Old 01-28-2009, 06:21 PM   #4
wait a minute, if the hole's ALREADY drilled, how did you know what size you needed w/o any anchor ? ? ? more'n likely a tapcon ( concrete screw ) is out & you'll need a drop-in anchor ( lead shield of proper dimension gets hammered into the hole then a bolt's turned into the anchor ),,, yes, concrete anchors're special
yesitsconcrete is offline   Reply With Quote
Old 01-28-2009, 07:34 PM   #5
Remodeling Contractor
I agree.. tapcons are out if the hole is already drilled. And it is not really strong enough for your purpose. You will need a expanding anchor to match the hole you drilled and most likely it is best now to use an epoxy to seal it in place.
Old 01-28-2009, 07:48 PM   #6
Don't know it all, yet!
Lags and shields or Redheads should do it, but just to ask- How much pull are you planning on needing to hold?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 01-28-2009, 09:28 PM   #7
' hold ' as in shear or pullout strength - good point, fart !
Old 02-02-2009, 10:47 AM   #8
There are alot of ways.
Check out the installation videos on www.concretefasteners.com
There are many different options. On this site you can get technical information and they have videos of profesionals installing concrete anchors.
Bronx is offline   Reply With Quote
Old 08-14-2013, 08:14 PM   #9
Yeah using the right Concrete Screw is important - here are some <a href="http://www.anzor.com.au/stainless-steel-masonry-concrete-anchors/product">Concrete Screw/Masonry Anchor</a> options with their pull out loads.
jamieh100 is offline   Reply With Quote
Old 08-14-2013, 08:15 PM   #10
Concrete Screw/Masonry Screw Options I mean
Old 08-14-2013, 08:35 PM   #11
Too Short? Cut it Again!
Hope the OP gets back to us. We don't yet know what he is mounting and what it will hold.
I am wondering if one central hole, even with an anchor, will do the trick or if he is going to need some sort of ring on a deck plate fastened at four corners with bolts and anchors. And epoxy for the main shaft of the thing if there is one?
OP if you do use lead anchors, you may get an electrolytic reaction between unlike metals over time. Definitely seal with silicone to try and hold some of the moisture out of the cavity.
Old 08-14-2013, 08:37 PM   #12
Never mind. Just looked. This thread is 4 years and 7 months old. I suspect he has resolved this by now.
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (08-14-2013)
Tags
concrete floor , laimana2000
best way to fasten backer board? ponch37300 Flooring 17 01-06-2009 01:59 PM
