How Do I Drop A Basement Ceiling 1-ft? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 05:24 PM   #1
How do I drop a basement ceiling 1-ft?
I'm currently in process of finishing my basement (with 9' ceilings), but due to a beam that runs through the middle of the bathroom, I need to drop the ceiling 1' for the entire room. What's the best/easiest way to do this? Dimensions of the bathroom are about 7x9. To run any new joisting perpendicular to the existing, they'll run the 7' length.
I know I'll have more questions as I go...and have already found great info on this site.
Thanks in advance!
ThunderCAT is offline   Reply With Quote
Old 02-02-2009, 06:21 PM   #2
Old School
Willie T's Avatar
What kind of ceiling do you want to put in?
Does the beam run "exactly" down the center of the room? This could work out to be part of a truly decorative and impressive ceiling treatment.
Do you want to incorporate recessed lighting? It could be done using this beam as part of a striking geometric grid layout.
Are you planning a vent system?
Will your tile run all the way to the ceiling in any part of the bathroom? I ask this because you may want to figure the height to make full tiles fit just right. It makes for a more professional looking job.
Willie T
Old 02-02-2009, 07:47 PM   #3
The beam doesn't run down the center exactly. It's not a problem in any other part of the basement (at least that I can foresee at the moment), except for the bathroom. The ceiling will be sheetrocked, and I don't anticipate tiling all the way to the ceiling at any point.
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 09:12 PM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 07:24 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
