How Do I CAP Exterior Window Trim? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 10:13 AM   #1
Question
How do I CAP exterior window trim?
I have old wood around new windows (I just bought the house) and would like to cover the wooden trim with vinyl or aluminum. Can someone point me in the direction of a tutorial on how to do this project myself? A video would be helpful, or just instructions!
lorlormommie is offline   Reply With Quote
Old 03-26-2010, 09:10 PM   #2
Rewards Points: 5,336
Covering wood trim conceals the visual to any damge that will occur. I would replace the wood with one of the Polyboard materials out there.
Ron
Old 03-27-2010, 07:15 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Window capping really isn't a novice level task. You need access to and experience on a break, as well as the knowledge to flash ind install it properly. If done incorrectly it can direct water INTO the wall. You can probably find somebody local to do it for anywhere between $30-$70 per window including materials. You can try it if you're feeling very ambitious, you just might end up spending more by doing it yourself.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-27-2010, 08:59 PM   #4
kwikfishron's Avatar
Rewards Points: 378
I completely agree with HomeSealed, it took me many, many jobs of pretending I knew what I was doing, bending metal and installing window wraps, fascia etc. before I even started to liked my own work.
Hire it out and go look at a few jobs your prospective trim wrapper has done.
kwikfishron is online now   Reply With Quote
Tags
window capping
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
