How Do I Build These Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 07:11 PM   #1
Non-Handyman
How do I build these stairs
Any tricks before I dig in?
These are a little fancy, but I want them to be structurally/design similar to the pic.
Thanks,
Dave
Dave W. is offline   Reply With Quote
Old 06-24-2009, 08:02 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
Stair building is an advanced level carpentry skill, especially something with rounded treads and other detailed touches like in the picture. Do you have real high level carpentry skills and lots of tools?
adpanko is offline   Reply With Quote
Old 06-24-2009, 08:18 PM   #3
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
Ed,
I echo ad!
You are looking at a very complex project and it is so complex it would be impossible for me (someone else might be able to talk you through the project however I can't) to point you in the right direction. Depending upon the home the layout what the room looks like how much head space you have how much available run you have how many treads you will need ... and the list goes on and on. To top it off there is a banister with balusters and handrails turnouts goose necks etc that complicate it even more. This is a project that would be tough for an entry level carpenter and would definitely be a fairly significant project for a seasoned professional carpenter to tackle.
I thin the first question that was presented sums it up best do you have a lot of
1) tools
2) skill
3) patience
If you have those three then you probably would not be here. I would advise you to hire this project out to a very experienced carpenter as the components to this project are expensive and a person does not want to practice or make this a trial run unless you have plenty of money and a good sense of humor.
Good luck and be safe!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 06-24-2009, 08:22 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
I think I would build 4 half circles and stack them up.
The finish treads are going to be a biach but with patience and a lot of waste material...
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-24-2009, 11:03 PM   #5
looks like the bottom 3 steps are three pices of wood. almost like a butt jounted picture frame with curved sides.
gregdonovan is offline   Reply With Quote
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
Concrete stairs jmat1980 Building & Construction 2 04-19-2008 12:45 AM
Prefab or custom stairs? brokie General DIY Discussions 1 01-21-2008 08:11 PM
Stairs Build Cost helpless handyman Carpentry 20 04-11-2007 07:33 AM
