How Do I Build A House On Blocks? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 12:27 PM   #1
how do I build a house on blocks?
I am in eastern Canada and I am going to build a small house 20x36 (or so) this summer and I want it to sit on blocks like a mini home. I was thinking of useing hemlock beams sitting on concrete blocks or more hemlock. any thoughts? I am also wondering how to insulate the floor. Can I just use sheets of ridged foam or batts of insulation? It does get pretty cold in the winter around here. an thoughts and any websites will help me a lot thanks!
farmer260 is offline   Reply With Quote
Old 03-22-2011, 04:46 PM   #2
Framing Contractor
Ask your building inspector that question.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-22-2011, 06:26 PM   #3
ok let me put it this way im building a shed not a house lol! i am building on a farm and I dont care if it gets inspected im never going to sell it and its just going to be a temp. "shed" anyway.
Old 03-23-2011, 09:57 AM   #4
The kind of construction you're talking about I've heard called "pier and beam."
It used to be typical in the South (USA).
I think I'd make a pole structure instead though. You need to get your foundation (piers, poles, or whatever) below the frost line. It's easier to put poles that deep than block piers.
Go to your local library and see if they have books on pole structures. My library has several. They include tables to help you size the beams and the poles.
pyper is offline   Reply With Quote
Old 03-23-2011, 10:27 AM   #5
ya i know about that kind of construction I have done that kind of work for 7 years now. I am trying to build ontop of the ground so the "shed" can be moved someday.
Old 03-23-2011, 10:41 AM   #6
Rewards Points: 5,336
You have the ability to move a 20'x36' building? You can still move a pole structure. Just cut the poles.
Ron
Old 03-23-2011, 10:44 AM   #7
yup I can move it no problem. I want to build on beams that sit on blocks im just not sure how yet. That way i can set the building down on the beams and slide it or put it on a trailer and move it. A building like that doesnt really weigh that much.
Old 03-23-2011, 10:53 AM   #8
I ask the impossible!
Rewards Points: 640
My house in Michigan was built this way in 1917, 4 years before the city incorporated, and I think it's fair to say that it wasn't intended to be moved, nobody has actually tried to move it, but that has not stopped it from moving on its own anyway. Whenever I have spoken of how my house is constructed, it has always been as an example of what not to do. Monday I had an experienced concrete guy out to get a quote on a replacement driveway, and he couldn't be convinced that I have a house supported by blocks with no foundation until he actually got into the crawlspace and saw it for himself.
As I said, my house was built in 1917. It was balloon framed. There are 3 spread footungs under a central beam, floor joists rest on top of this beam and are butted at the center of the beam (no overlap as is typical current construction practice. Not a single floor joist under the first floor is original. Very few are not sistered. Very few of these new boards lack wood rot at the ends.
I must reiterate that this is not a good way to do things. The floor joists are supported by stacks of concrete blocks around the outside of the house and at various places between there and the center beam. These stacks have sunken into the sand. The presence of sand and the fact the crawlspace is heated have probably worked in the houses favor because the sand provides good drainage and the heat keeps the water in the sand from freezing.
With that said, the floor is crowning with a high spot at the center where the beam is sitting on some footings and low at the perimeter where there is no foundation under the cement blocks. The stairway is putting extra load causing an area of floor to be depressed, and a 3 to 4" sag in the beam supporting the second floor.
What I am doing to improve the situation is that I am adding beams at the perimeter and to replace the center beam (which has its own problems, such as being undersized and having joints that are not supported) These will be supported by 6x6 posts rigidly attached to the beam and spread footings. I am using plans from an engineer, and placement constraints are causing me to exceed the engineer's specifications by increasing the number of posts and beams I'm putting in.
My spread footings are not going to the frost line, later (3-4 years) I'll be having a footing put in for a foundation wall that will be below the frost line but that's not practical with my finances for now. I've gathered that because these are in conditioned (heated) space this is acceptable since the ground under them shouldn't be freezing.
Insulation should be on the crawlspace walls, not the floor above the crawlspace unless the crawlspace is open - but then again, if the space is open, then you'll have freezing under your support columns. And you'll have less defence against unwanted pests. Still, without a foundation wall, I can say from experience that rats can find their way in.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 04-01-2011, 04:03 AM   #9
But I think it much better to build a small house than a shed....it makes you feel relax & comfortable than a shed..
desiree_furman is offline   Reply With Quote
Old 04-01-2011, 08:28 AM   #10
This makes no sense at all.
Ron
Old 04-01-2011, 09:14 AM   #11
Carpenter
dtsman's Avatar
Set up your batten boards and strings and lay out your footers and pour to the frost line, then stack your block to level heights. I would use 3 or 4 - 20' beams, tie their ends together with what ever is appropriate for their size. Set the footers at each end and one in the middle of each beam.
Then lay your floor joist perpendicular on top of them. The size of the floor joist will depend on the number of beams. If you use 4 you can use 2x6 joist, if you use 3 you will need at least 2x8's.
Here is a link for joist spans for wood types.
http://www.awc.org/calculators/span/...orizontal+Span
Most important, flash the block before setting your beams so the wood doesn't set directly on concrete. It will absorb moisture from the block, and that part of the wood will stay wet and begin to crush.
As mentioned before, common practice down here in the south but can be used anywhere.
If you know you are going to move it, install bracing in the beams and floor joist while you are building so you don't have to climb under there and do it later.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Buying an older house jayinwww Project Showcase 3 06-10-2011 06:43 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
