How Do I Build A Flush Header For A Basement Doorway? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 09:53 AM   #1
Rewards Points: 508
How do I build a flush header for a basement doorway?
I would like to use a flush header over an exterior door in my walk-out basement. I recently discovered that I have no rim joists running parallel to the floor joists, i.e., the exterior walls rest directly on the floor joists.
Under normal circumstances, I would cut back the floor joists to double up the rim joist over the doorway and use joist hangers to suspend the floor joists from the doubled up rim joist/flush beam.
What should I do in the case of no rim joist? How do I get the header to fit? Should I shave down the header until I can slide it easily into place from the outside?
benjamincall is offline   Reply With Quote
Old 09-07-2011, 11:06 AM   #2
Rewards Points: 5,336
The process is exactly the same, whether there's a rim joist or not. Build a full header, install it. Use the hangers if there's less the an inch of bearing on the sill plate.
Ron
B. Franklin 1759
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Doorway Header kgiles Carpentry 0 07-19-2011 08:31 PM
Can I build a wall over a window in basement? Rife Building & Construction 6 08-30-2010 06:40 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 03:52 PM
