Old 03-30-2010, 07:33 PM   #1
Question
How do I Build Brick planters around patio
I want to build a brick flower planter around my patio approximately 12" high.
However, I really do not want to pour a concrete footer for this.
I was thinking about pea gravel with one layer of cinder blocks for the base.
The brick veneer would then be laid on top ( and around ) the cinder blocks about 12" high.
Question : If I tamp the pea gravel & mortar the cinder blocks, & keep the wall at 12", will the gravel & cinder blocks work for the foundation, or will I end up with cracks in the planters ( brick Veneer ) from movement ?
Mark
itaska71 is offline   Reply With Quote
Old 03-30-2010, 07:54 PM   #2
Xtreme DIY'r
Where are you located ?
Old 03-30-2010, 08:41 PM   #3
fix it
Retaining wall blocks will give a similar look without a concrete footer or mortar on the courses.
detailedEye is offline   Reply With Quote
Old 03-31-2010, 05:24 PM   #4
I am in Cincinnati Ohio
I am having trbl navigating this site.
When I 1st opened your reply you sent a link about gravel footers. Today I can not find it
brick paver patio fishin dude Landscaping & Lawn Care 7 03-04-2010 12:10 AM
Redwood Deck Over existing brick paver patio areacode516 General Discussion 3 04-12-2009 10:09 PM
Brick haze on brick over slab patio joeconroy Building & Construction 17 09-08-2008 01:44 PM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 08:47 AM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 08:15 AM
