How Do I Attach Metal Numbers To Stucco Exterior - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 06:51 PM   #1
How do I attach metal numbers to stucco exterior
Hello! I have cut house numbers from sheet metal and need to adhere them to my house which has a stucco exterior. There are no holes in the numbers or supports on the back from which to hang them, so I would like to glue them, though not permanently, so Gorilla Glue is out. I tried grout but it did not hold. Any recommendations? Thank you for your time. janet@regan3.com
JanJan is offline   Reply With Quote
Old 01-22-2011, 08:49 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Clear silicone adhesive/sealer globs (several small ones per number) will do fine and can make up the texture and surface variations. Depending on the weight and thickness, use something like duct tape to temporarily hold them in place for a day, since gravity can male them creep downward.
I put some up 15-20 years ago on brick and last I saw, they still looked fine.
Dick
concretemasonry is online now   Reply With Quote
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 06:54 AM
Attaching metal flashing to Faux stucco sdcurt Roofing/Siding 3 10-10-2010 05:51 PM
Do I have to remove stucco to attach deck ledger? brandon272 Carpentry 5 04-03-2009 10:57 AM
New exterior french door install in a stucco wall lightninrodman Building & Construction 2 06-30-2007 12:08 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 11:04 AM
