How Do Engineers Determine Weight Limit For A Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 05:29 PM   #1
Rewards Points: 1,062
How do engineers determine weight limit for a roof?
People,
Now, Im trying to figure out if my flat roof can hold a certain weight which hopefully, will be a new exterior floor on top of it (many posts on my recent threads on various issues involved with this multi faceted project).
Yes, garage roof is made up of 2X6, 16" apart as usual, spanning a 2 car concrete poured foundation garage. 2X6's cross the garage from left to right, and down the middle of the beams if a massive 3X6 supporting the center of all the 2x6's. Of course, on each end the 2x6's are resting on the foundation. Roof has 1/2" ply currently with old asphalt membrane.
How do you determine the max weight of such a roof structure? Can one? Do we need a book?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-31-2013, 06:21 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... Is this Floor, the same size as the roof,..??
If so, it'll be bridgin' the roof, 'n the floor weight will be transferred to the Walls, not the roof...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
noquacks (01-31-2013)
Old 01-31-2013, 06:48 PM   #3
Thnaks, Bondo. Yes, floor is same size, matter of fact, roof IS the floor from above. But, right now, it IS bridged, and I want to get away from that if able to, so how does one calculate the max weight? Thers gotta be a way. Even if I go with a bridge, still would like to know.
Old 01-31-2013, 06:50 PM   #4
heres the picture of it: (from above/outside, of course)
Remodeling deck surface- How?
Old 01-31-2013, 08:25 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
whats the width of the garage..and where are you located. if you get any amount of snow and its more than 8' i would never use 2x6.. if your relating it to a floor system canadian code wont accept anything less than 2x8 for a floor. 2x6's are allowed only in the case of a small landing for a stairwell
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
noquacks (02-02-2013)
Old 02-01-2013, 01:29 PM   #6
Rewards Points: 93
i lol'd at this question. i'm a structural engineer by profession though i do industrial and not residential.
i dont think you will be able to do this the "engineer" way. it involves a lot of math. you need to know the maximum dead and live load then compute for maximum moment and shear and deflection and compare it to the capacity of the beams per buidling code.
better ask a contractor or superintendent, they can give you intelligent advice based on gut feel or experience. which maybe dangerous if you ask a structural engineer.
dumbengineer is offline   Reply With Quote
The Following 3 Users Say Thank You to dumbengineer For This Useful Post:
epson (02-01-2013), noquacks (02-02-2013), woodworkbykirk (02-01-2013)
Old 02-01-2013, 02:25 PM   #7
Rewards Points: 502
From quick back-of-envelope calcs.,assuming a live load of 40 psf and dead load 10 psf, the bending stress in your joists will be roughly 1000 psi, which is near the limit for lower-grade timber. Your deflection will probably be within the limit (just).
But you don't say what the "massive" 3x6 is (timber? steel? polystyrene?). Whatever it is,it will be supporting half the weight and it, and the supports, are the critical things here.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
Old 02-01-2013, 06:27 PM   #8
Rewards Points: 13,276
3 X 6 is massive? Now that's funny.
If that's a soild wooden beam it has almost no side load strength.
Old 02-02-2013, 08:35 AM   #9
garage is just enough to fit 2 cars plus 2' on each side (one left, one right), plust the space between cars, about 3". A 2 car garage. Do we need to the inch? Im in S Cal. No snow. just pricey gasoline and high rent/income taxes.
Old 02-02-2013, 08:38 AM   #10
I will confirm the size of our infamous MASSIVE beam, people.........prepare yourselves.....
Old 02-02-2013, 08:40 AM   #11
Meanwhile, thinking ahead of myself (a dengerous passtime), my intent is, if roof structure is strong enough, to lay on top of membrane, hardyboard, then seal, then MAYBE thin setted ceramic tile. I know its not revcomended, but just want to be able to at least throw out the idea permanently IF the structure wont hold it.
Old 02-02-2013, 09:12 AM   #12
Rewards Points: 630
try this for your membrane under tile will do drainage and crack isolation
http://www.schluter.com/142.aspx
or you could do this also
http://www.decksdirect.com/hardware-...-deck-supports
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-02-2013, 04:53 PM   #13
no matter what size beam your using i wouldnt be using 2x6` they will still sag unless you plan on having 3 beams for the ceiling joists to sit on keeping the joist spans under 7 `
Determine max weight capacity of deck Fantastic Building & Construction 12 05-10-2012 01:49 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
roof waste weight canadaclub Roofing/Siding 4 07-01-2010 03:31 PM
Makeup Counter Weight Limit? greylockwood Carpentry 1 02-14-2010 08:31 PM
Is there a weight limit in a Garden Window? rwith General DIY Discussions 5 05-15-2009 05:02 PM
