How To Dig A Post Hole >4' Deep? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 11:15 AM   #1
Rewards Points: 264
How to dig a post hole >4' deep?
We want to run a temporary electrical drop onto some vacant land, which is no problem with the PoCo. They want a 20' long 6x6 post buried 5' below ground though. With post-hole-diggers I can get near 4' but what do I do to get deeper? We only need one pole so I'd rather not go rent equipment for one stupid hole but can't think of another way.
Thanks!
moneymgmt is offline   Reply With Quote
Old 04-30-2009, 11:21 AM   #2
Cut a foot off the the pole and tell them it's in the ground 5'.
jerryh3 is offline   Reply With Quote
Old 04-30-2009, 02:24 PM   #3
Joe F's Avatar
Rewards Points: 294
I don't see this as a code issue since it's a temp. Is the Power company actually going to inspect the hole before you fill it?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 04-30-2009, 02:48 PM   #4
Old School
Willie T's Avatar
Well, if you don't have a good pair of double hinged post hole diggers like this, http://theholedeal.com/ , dig a hole with a shovel about 30 to 36" deep, and stand in this hole to dig the remaining hole with post hole diggers. They are 60 bucks and $12 shipping.
Willie T
Old 05-01-2009, 02:51 PM   #5
You could also use your post hole diggers to break the dirt up, then suck it out with a shop vac.
lockman is offline   Reply With Quote
Old 05-01-2009, 02:59 PM   #6
Once you near 3' depth dig the sides out at an angle at the top of the hole
That will allow you to dig deeper then 4'
Old 05-01-2009, 07:48 PM   #7
SNC
thats what mexicans are for
SNC is offline   Reply With Quote
Old 05-02-2009, 06:47 AM   #8
Think
" I like the way you think"
SULTINI is offline   Reply With Quote
Old 05-03-2009, 10:21 PM   #9
the correct answer is jerry's,,, the power co won't look down inside the pole's hole
yesitsconcrete is offline   Reply With Quote
Old 05-04-2009, 04:25 AM   #10
Thank you. I've learned to be very creative over time.
Old 05-04-2009, 05:16 AM   #11
Rewards Points: 150
Send a message via AIM to Bocolo
Not nice.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Post mounted electrical receptacle ¯¯NI¯l¯RO¯¯ Electrical 13 04-19-2010 02:20 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 02:39 PM
Cold Weather Concrete in Post Hole OK?? Jerrycast Building & Construction 6 01-25-2008 09:47 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
