How To Determine How Many Windows Go In New Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 07:25 PM   #1
How to determine how many windows go in new basement
We are having a new basement poured and don't know how many windows we have to have or need to have. I know more light is better but is there a code for this?
Joyal is offline   Reply With Quote
Old 08-03-2012, 07:50 PM   #2
Rewards Points: 12,812
Why are you not asking your local building dept.? Even the guys doing the foundation should know the local codes, if not there should not be doing it.
No one here even know where you live. If you go back and edit your profile and add your location someone may just know the ansewer.
Was there building permits and drawings submitted?
user1007 (08-03-2012)
Old 08-03-2012, 08:11 PM   #3
Too Short? Cut it Again!
Depending on how you are using it, there may be specific ingress/egress codes just to start. Not only will they indicate how many you need but at what height for your area.
Old 08-03-2012, 08:58 PM   #4
Rewards Points: 616
but if you do not pull permits it saves money upfront and usually more than triples the cost at the end or maybe like in some townships here only permit is zoning to make sure it is not on neighbors or effecting neighbors land (like water diverting)
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Basement Vinyl Windows - replace or not, thats the question! chadurban Carpentry 0 10-01-2009 11:37 AM
Framing/Finishing around basement windows archiero Remodeling 7 05-08-2009 11:04 PM
Basement windows in masonry walls dave11 Building & Construction 1 03-20-2009 09:28 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 09:07 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
