How To Determine Existing Insulation R-Value - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 01:36 PM   #1
How to determine existing insulation R-Value
I started replacing my old insulation. I'm trying to determine if the effort is really worth it. The old insulation is just over 1/2 as thick as R-13, but on one side is thick (for paper) and shiny metallic looking. the back side is paper . I've attached a picture of it, next to a piece of r-13. I don't need to know the exact r-value of the old insulation, but I trying to figure out if I'm making my house better. Some of my rooms and walls are cold in the winter (one cabinet in the kitchen feels like a mini fridge).
elcid99 is offline   Reply With Quote
Old 08-03-2012, 03:14 PM   #2
Rewards Points: 13,732
What is it your trying to insulate, walls, ceiling?
http://www.energystar.gov/index.cfm?...sulation_table
Old 08-03-2012, 05:25 PM   #3
I'm insulating the walls. According to that link, I'm zone 4.
Old 08-05-2012, 04:31 PM   #4
Registered User
Rewards Points: 5,516
It is always worth it.... that foil-faced is around R-7-9, less if not in full contact with the drywall; The "biggest loser" in fiberglass insulation....
Gary
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Rigid Foam Insulation over existing wood siding Hexar Building & Construction 30 04-23-2010 07:15 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
