I have a 2.5-year-old walkout basement home, brick front with siding on back and sides. I just noticed that water appears to be getting in at the foundation in the front of the house.
Here are photos of our storm shelter area in the basement. If you’ll notice the yellow arrows, they indicate where on the plywood flooring above I have black, damp discoloration. It spans about a 5-foot length. Is this black mold?
These are photos of the front of the house, where I believe the water is getting in. The 5-ft length of black discoloration in the photos above pretty closely lines up with where the downspout is in the photos below.
Questions:
1. Do you believe this is the most likely cause of the black discoloration I see on the plywood in my storm shelter?
2. Do you believe it is black mold, or something else?
3. Should I simply first try installing a downspout extender to direct the water to the end of my flower bed where the stone wall is?
4. What should I do about the black discoloration on the wood – how should I treat it (if even just to cover up the unsightliness)?
5. Do I need to call a professional yet? If so, who do I call (e.g. plumber, foundation contractor, etc.)?
Start by taking a shovel and digging down by the foundation near that downspout and see if any cracks are visible. I would also definitely extend that downspout. DO not discount those window sills also.
And when you have dug it down, look at the base of the brick. Likely there are weeps to allow condensation to drain away. If your landscaping is higher than the weeps, then you've got an excellent path for water to enter instead of exit.......... and yes that black stuff is probably mold, and should probably be addressed as soon as the water issue is solved.
Now that I see the surface of the floor, I would think that the water is draining off the concrete floor and towards the nice brick on the edge. It is draining down when it hits that joint.
You can certainly caulk that with some Vulkem, but I would think with a deck detailed like that, one would want a secondary drainage plane below.
I like the concrete with brick edging, but this will always be a maintenance problem.
I'd also wonder at the design that would have what appears to be two moderate sized roof planes that drain into a single downspout which is not connected to the storm system but is left to drain into a landscaping bed as pictured.
Now it makes a little more sense, it's under the porch above.
I would ask the builder if the lumber and OSB can be removed, as it should have only been used as a temporary form. No reason to keep it in place if it's only going to rot away anyways. That stoop "should" have been built to be self supporting once cured.
I see these problems on a regular basis. Most concrete guys, or even GC's, don't take the time, effort, or money to do them correctly. They feel like it's just a normal concrete slab, and believe that concrete is "waterproof" in itself, which certainly isn't the case. The proper way to construct these is to treat as a roof, which is what it truly is. It should have an adaquate membrane under the concrete, typically 60 mil rubber used on flat roofs, flashed into the walls of the house. The stoop should be waterproof BEFORE any concrete is poured, and the concrete is used to protect the membrane........
The area under the concrete and brick should be sloped towards the outside and have a waterproof membrane on it.
It should also be self-supporting after the concrete has cured.
You should also be able to insulate it.
At this point, you can try some surface waterproofing. It seems they used to advertise some Thompson product for waterproofing such surfaces. And of course you have to seal up the big holes first.
You may still have some recourse with the builder. I'm not sure how important it is if the house is 3 months old or five years. This installation is either done right or not. It also doesn't matter if you are the first owner or the fifth. The job isn't up to industry standards. It was designed improperly and obviously it leaks. It is like a faulty ignition switch on a car.
One option is to remove the stoop from the house. Then you will be left with some brick coming up from the footings. Theoretically, there should be some flashing behind the siding (brick veneer) to keep the water from running down the wall and into your basement. However, given that this whole entry is covered by a roof, I think you can skip the flashing.
So you need to form up a floor below the stoop which will support a concrete pour. Slope the concrete out and pour the pre-slope. Make it 4" thick if you need to to support the span. You'll need re-bar in it, etc. You will need to have it so that some brick on the house side and sides will support the concrete after it cures. It will be held up on the outside by the foundation.
Now you have a pre-slope which will support itself after you strip the forms. Now you can pour another slab/brick rowlock on top of this or whatever. It will have the same slope towards the exterior. Any water which passes through this concrete and brickwork will hit the membrane and slab below and flow towards the outside.
Option 2 would be to just go over the top of what you have. Treat what you have as the pre-slope and go over it with a membrane and a new layer. I doubt you have the height for this option.
Think this over. Maybe some other guys will respond and have better ideas than I have. There are some experienced guys out there. I think Jomama has a good idea of what you are dealing with.
It shouldn't be too big of a deal to remove the stoop and re-do it. You may be able to market this to the builder as a way for him to understand what is wrong with his system and come up with a mitigation system.
It appears that your landscaping is too high to begin with. As for whether that black marking is mold or not. You would need to get a test kit to find out. Your local city/county Public Health would have them.
So the brick on the front is a brick veneer? It may be that window sill which is just a rowlock course of brick which is leaking
I use to have rowlocks for my window sills on the front brick veneer of my home. The mortar joints between the rowlocks leaked and without the proper flashing behind, water ran under window and into house.
My solution was to eliminate the rowlock window sills and replace with limestone.
From the camera view it may look like the water is running off the front face of the brick but I assure you it is not. All the water is being drawn into that mortar joint, running down behind the brick veneer and ending up leaking out the top of the bay window.
Also here is a link to a youtube video showing the mortar joints leaking:
It's level with the walkway to the front porch though. If I lowered it, I'd have a steep drop-off there on the left side (if facing house) of the walkway.
Sorry if that's not what you wanted to hear but think about it, your landscaping is above and against the cold joint between your foundation and the bottom of your floor joist and sill plate.
Your landscaping is acting as a pond/sponge holding water and allowing it to seep in at the foundation to sill location.
This is one of the reasons I have big issues with contractors and inspectors alike. At no point did this seem like a bad idea or even worth mentioning.
What is the flashing detail on the wall? Hopefully there will be housewrap behind the veneer which will lead water down the wall. It would be easier to understand water coming in at the top of the concrete wall if the veneer sits on the top of the wall. To have water coming in at the sill plate of the framed wall and not the top of the concrete wall (lower down) is strange.
Does the veneer start on the top of the wall or is there a brick ledge?
Why do you have a downspout near an entry? You must have a bit of roof over the entry which this downspout serves?
I would surely extend that downspout out to the edge of the small retaining wall anyway.
I can't tell whether there is any slope to your window sill.
It also appears that your window sills don't extend out beyond the veneer.
From your original photo, am I correct when I say that the floor joists are resting on the concrete wall?
I can't see how much roof is draining into that downspout, but it looks like a very small amount.
How is the concrete floor of your recessed entry detailed? It looks like you have some floor joists under the concrete, then some osb. Is there some tar paper or plastic or something above the osb?
What is the width of those floor joists under the concrete?
The sills do extend a bit beyond the veneer (how do we know this is veneer vs. real brick?), and slope slightly downward away from the house:
The floor joists are resting on concrete, yes. They measure 1.5" x 5.5". They are treated floor joists, under treated plywood, topped off with ice-and-water shield.
I'm not sure why someone would frame up a recessed entry like that, but there must have been a reason.
I wonder if the concrete is sloped, and the osb floor underneath?
Even if the waterproofing is good and holding up well and the osb is pre-sloped, you have a potential for a lot of condensation against that osb in the cool basement in the summer.
And of course you have a very cold spot there in the winter.
It is more common here to have the recessed entry or stoop or porch supported temporarily for the concrete placement, then the framing/floor sheathing can be removed.
I just insulated one about 4' deep and 6' long which was bare concrete. There was no waterproofing underneath and I put 2" of xps against it. It is covered by a 40" soffit and sloped well on the top. There is no sign of water coming in.
Anyway, I'm just trying to figure out how your house was built.
I wouldn't rule out that mold coming from condensation water.
I would also insulate your rim joist all the way around before it turns black as well.
Veneer is real brick, It just means there is a wall behind it. Doesn't look like water is coming from garden unless there is a step down into that room. I wouldn't rule out the window. I would open the window and pour a glass of water on the inside from the screen to simulate water hitting the window. See if it runs out the weep holes under screen.
I just forwarded this thread to my builder. His response:
"It's not the grade. I guarantee the water is coming in between the brick and concrete on the front porch. I will run by and caulk the space to see if that takes care of it. Also, the wood is turning black because it is wet - it's not mold. The way that porch is poured, all the wood could come out and the porch would stay. So, structure wise it will not go anywhere."
He's under no obligation to take a look at this, so I sincerely appreciate his willingness to help. I told him this makes sense because the black areas on the wood are a bit farther north than the downspout, pretty much right in line with the front step.
Do not let your builder "Caulk" their problem. Get an inspector in and have them do a full write up. Your builder is just trying to keep you and them out of court. Because they failed to do the job properly.
It is 100% Landscaping that is causing water to get down there. The pictures do not lie.
I would have no grounds to take him to court if I wanted to. Why are you so convinced it's landscaping when the affected area of the wood is directly behind/under the porch step?
It would not be that hard Hammerlane for the OP to run black flex pipe into the ground and out the side below the slope. To help funnel that water out of there.
To me. It is sounding like the OP does not want upset the landscaping, which is not that hard to do. Any local mom & pop Garden Center would have the containers to place the plants into. The other materials would go onto a tarp as is done in these kind of cases.
Simple fix that can be done in a weekend. But too many excuses are coming from the OP, that they do not want to attempt to correct.
Yeah controlling the water further away from the home before releasing it into the yard would be better. But in my opinion the best way would of been to tie into the storm system. From the photo I bet there is a swale between the posters yard and the neighbors and dumping that water there would mush up the ground there.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
