I have a 2.5-year-old walkout basement home, brick front with siding on back and sides. I just noticed that water appears to be getting in at the foundation in the front of the house.
Here are photos of our storm shelter area in the basement. If you’ll notice the yellow arrows, they indicate where on the plywood flooring above I have black, damp discoloration. It spans about a 5-foot length. Is this black mold?
These are photos of the front of the house, where I believe the water is getting in. The 5-ft length of black discoloration in the photos above pretty closely lines up with where the downspout is in the photos below.
Questions:
1. Do you believe this is the most likely cause of the black discoloration I see on the plywood in my storm shelter?
2. Do you believe it is black mold, or something else?
3. Should I simply first try installing a downspout extender to direct the water to the end of my flower bed where the stone wall is?
4. What should I do about the black discoloration on the wood – how should I treat it (if even just to cover up the unsightliness)?
5. Do I need to call a professional yet? If so, who do I call (e.g. plumber, foundation contractor, etc.)?
So what would be the best way to patch/seal the crack in the concrete that runs the entire width of the back edge of the bottom step (see 2nd photo in my post #23)?
The way that I have seen a recessed entry done is that as the brickwork is coming up, some brick (which will be below the slab) are set in a bit, in order to allow a piece of plywood to be supported.
The slab is then poured on top of this piece of plywood.
This system is wrong, because as the plywood deteriorates, the only thing holding the slab up is the bond along the brick veneer and on top of the brick on the outside.
This bond is usually sufficient.
However, the best way to do this would seem to be to set up a form inside the bottom of the stoop to support the floor pour, then go below and strip it later.
Where the landscaping meets the wall, is there any protection that would handle an excessive amount of water and moisture.
Is there a sprinkler system, that would add insult.?
In the other areas mentioned a simple caulking would help but, I doubt that's your problem.
You may also have a problem to the right of the side walk.?
Your builder will have that problem in every home he has done with that detail. He may as well have callers press *8 if they have a leak in their basement under the entry, then have a recording explain what the problem is.
The area under the concrete and brick should be sloped towards the outside and have a waterproof membrane on it.
It should also be self-supporting after the concrete has cured.
You should also be able to insulate it.
At this point, you can try some surface waterproofing. It seems they used to advertise some Thompson product for waterproofing such surfaces. And of course you have to seal up the big holes first.
You may still have some recourse with the builder. I'm not sure how important it is if the house is 3 months old or five years. This installation is either done right or not. It also doesn't matter if you are the first owner or the fifth. The job isn't up to industry standards. It was designed improperly and obviously it leaks. It is like a faulty ignition switch on a car.
One option is to remove the stoop from the house. Then you will be left with some brick coming up from the footings. Theoretically, there should be some flashing behind the siding (brick veneer) to keep the water from running down the wall and into your basement. However, given that this whole entry is covered by a roof, I think you can skip the flashing.
So you need to form up a floor below the stoop which will support a concrete pour. Slope the concrete out and pour the pre-slope. Make it 4" thick if you need to to support the span. You'll need re-bar in it, etc. You will need to have it so that some brick on the house side and sides will support the concrete after it cures. It will be held up on the outside by the foundation.
Now you have a pre-slope which will support itself after you strip the forms. Now you can pour another slab/brick rowlock on top of this or whatever. It will have the same slope towards the exterior. Any water which passes through this concrete and brickwork will hit the membrane and slab below and flow towards the outside.
Option 2 would be to just go over the top of what you have. Treat what you have as the pre-slope and go over it with a membrane and a new layer. I doubt you have the height for this option.
Think this over. Maybe some other guys will respond and have better ideas than I have. There are some experienced guys out there. I think Jomama has a good idea of what you are dealing with.
It shouldn't be too big of a deal to remove the stoop and re-do it. You may be able to market this to the builder as a way for him to understand what is wrong with his system and come up with a mitigation system.
I know that's probably the right way to do it, but that would be extraordinarily expensive. I know we'd probably run into some unforeseen issues that would no doubt add to the cost. Just had someone (my mower/landscaper), who poured residential concrete for 14 years and is familiar with the construction of the homes on my block, over to assess the situation. He agrees the water is coming in at the seams on the stoop/porch, and recommended using concrete patch or the Vulkem I already have to seal the seams, then buy a bucket of concrete sealant and roll on two or three coats over the entire porch. He will also run the downspout under ground and daylight it just outside of the retaining wall.
You can get help from this article by a waterproofing company on how to fix a basement leak ............. Hope that helps!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
