How To Deal With Expansion Of Deck Boards? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 08:05 PM   #1
Rewards Points: 682
How to deal with expansion of deck boards?
I've read that one should have gaps between deck boards so they can expand width-wise with heat.
It isn't necessary to worry about lengthwise expansion, is it? When we had our deck repaired the carpenter just nailed them in. So those nails won't work loose because the boards try to expand along their length, right?
darsunt is offline   Reply With Quote
Old 02-02-2011, 08:17 PM   #2
Old School
Willie T's Avatar
Correct. They won't grow in length.
By the way... your boards won't expand. They shrink in width as they dry.
Willie T
Old 02-02-2011, 09:10 PM   #3
Civil Engineer
Rewards Points: 4,856
The cause of dimensional changes in wood is not heat, it is the moisture content of the wood. Different species have different expansion rates, but typically about a 2 percent dimensional change across the grain is maximum over the course of a season. So if the boards were dry when they were installed (i.e. kiln dried boards installed in the dry season), they will expand up to 2 percent in the summer.
A six inch wide board can change up to about 1/8 inch, hence the need for spacing between the boards. Some species expand more, you can check on the Forest Products Laboratory (WI) for the expansion rate for your particular deck board type. Boards do not typically change dimension along the grain.
Daniel Holzman is online now   Reply With Quote
Old 02-02-2011, 09:33 PM   #4
MikeKy55's Avatar
Rewards Points: 254
I built a 800 plus square foot deck this past summer in my back yard and the PT lumber was clearly wet. I jammed them tight together and by October there was a 3/16ths to 1/4" gap between all the boards. So to confirm what has been said, it's the moisture in the wood.
MikeKy55 is offline   Reply With Quote
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Leveling a deck denemante Building & Construction 10 08-24-2010 08:11 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
diagonal deck boards boots Carpentry 1 03-09-2007 08:15 PM
