Old 01-29-2009, 02:22 AM   #1
How-To: cut a channel in concrete?
My house is built on a concrete slab. I need to cut a channel in the slab to install electric to a new kitchen island. Need to fit a 3/4" PVC conduit - the length of the channel is about 5 feet.
  1. I was told that if it's a post tension slab, I cannot cut the channel - is this correct?
  2. How do I tell if it's a post tension slab?
  3. Suggestions on how to best cut the channel?
thx!
Vince
Old 01-29-2009, 06:16 AM   #2
If it's that sort of slab, you will need another route or redesign the layout.
Ron
Old 01-29-2009, 07:09 AM   #3
the channel can still be cut,,, post tension cables're installed in the middle of the slab & run in 1 direction - your odds of being parallel're 1 : 1 or 50 - 50 they're also install'd mid-point vertically.
look at the clap sides for patching cement - get a metal detector & ' sweep ' the floor
diamond blade as we cut all conc.
yesitsconcrete is offline   Reply With Quote
Old 01-29-2009, 10:46 AM   #4
Old School
Willie T's Avatar
The likelihood of your slab being post tension is very remote. It's a relatively expensive way to do a slab, and is generally considered unnecessary overkill in most residential construction. If you have no plans for your house to consult, try the building department. They keep records. Also, ask some of your neighbors. Chances are the houses in your area were built by the same contractor, and some of your neighbors may have plans.
Old 01-29-2009, 11:40 AM   #5
Probably 50% of the homes built in Austin in the last 20 years are post tensioned.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-30-2009, 06:52 AM   #6
hadn't realized the %age was that high, 'scar,,, expansive soils as in colorado ? ? ?
Old 01-31-2009, 12:15 PM   #7
I have gas!
Clutchcargo's Avatar
For my own edification, what is a post tension slab?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-31-2009, 02:21 PM   #8
High carbon steel cables, coated with grease and a plastic sleeve are laid throughout the slab (although a whole lot less than normal rebar), with one end terminating into an anchor, and the other end left loose outside the slab.
After the slab is placed and cured, a machine is attached to the loose end of the cable that pulls it to a certain amount of tension. That end is then restrained, the excess cable is cut off and the hole patched. This puts the entire slab under compression, which is a very good way to prevent slab failure.
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
