How To Cut Cement Backerboard? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 05:33 PM   #1
Rewards Points: 682
How to cut cement backerboard?
I was tempted to try to cut some cement backerboard with a sawzall yesterday (removing tile countertop) but stopped because I figure it would ruin the blade, which was meant for wood and nails.
Is it possible to cut backerboard with a sawzall? Would you have to buy a special blade?
THanks
darsunt is offline   Reply With Quote
Old 11-04-2011, 05:36 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can cut it but it will raise some dust. Less dust than some other methods tho. So you sacrifice a blade or two, not a big deal.
You can get recip blades with a corborundum edge, that would be the blade to use.
Old 11-05-2011, 06:44 AM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
ive cut it several ways. ive done it with a circular saw with a old wood blade, mini grinder, and the score and snap method. mind you score and snap takes quite a few passes with a knife but there is a tool made for this that has a carbide tooth.. most big box stores have it
woodworkbykirk is offline   Reply With Quote
Old 11-05-2011, 07:05 AM   #4
Rewards Points: 5,336
THanks
Circular saw with a diamond blade and a shop vacuum. Seal the room and wear a good mask and eye protection.
Ron
B. Franklin 1759
Old 11-05-2011, 07:36 AM   #5
DIY staff
Rewards Points: 7,174
If you are just demolishing the top---would it be possible to just drive a flat bar under the board and then just break it up with a hammer once you get a gap under it?
Old 11-05-2011, 10:31 AM   #6
mikes right. with the idea of using a recip.. you'll have to go to a supplier such as hilti to get a decent recip blade to cut the stuff.. very few big box stores sell recip blades that can actually cut concrete board and last more than a few inches of cut
Old 11-06-2011, 01:21 AM   #7
Rewards Points: 682
I have one last section to go. I've exposed two sides of plywood by knocking off tiles on the sides. 3rd side is against the wall, it is supported underneath by a piece of wood nailed to the wall. I think if I knock off one line of tiles above it, then I can tear off the supporting wood underneath, and that 3rd side will be loosed enough to pry the plywood up and off! So maybe I won't have to try to cut through.
Someone told me this stuff is not actually backerboard, it is two layers of concrete, each layer with mesh on both sides.
Old 11-06-2011, 05:07 AM   #8
DIY staff
That sounds like Durrock---a soft concrete with a nylon mesh on either side,---it will crumble easily with a few blows from a hammer.
cement backerboard needed? dangtran09 Flooring 5 08-10-2011 10:02 PM
How to fill gaps in cement backerboard? tripower Building & Construction 5 06-27-2009 03:31 PM
Correct Tape where Cement Backerboard meets Greenboard? cody21 Remodeling 12 06-26-2009 12:23 PM
Putting down a cement backerboard on floor Krichton Flooring 2 07-05-2006 02:13 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
