How To Cut Bullnose Corner Crown Molding Using Compound Miter Saw - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 02:45 AM   #1
How to cut bullnose corner crown molding using compound miter saw
Hello,
I'm trying to cut the crown molding to fit around a bullnose. I've been using the book by Wayne Drake. I get the small v-looking piece I cut for the middle around the bullnose, but how do I cut the two pieces adjacent to the center piece on either side (outside left/outside right)? What angle am I supposed to use? and do I keep the blade tilt the same? Is there a total angle I'm trying to obtain from all 4 cuts? I imagine it's 90 degrees, since this is the measure of the outside corner (270). The book doesn't explain this part well. Any ideas?
darryl0214 is offline   Reply With Quote
Old 03-15-2010, 06:58 AM   #2
Not entirely sure what you are trying to do. Crown molding is best done by coping inside corners, and experimental miter of outside corners. No wall is straight and no angle is 90 deg. That is the main rule for installing trim. If there is something you have to trim around, coping is usually the best way, but it takes practice, and often try/fit experimenting.
Old 12-29-2013, 11:44 AM   #3
Bullnose Corner
If its 270 all four cuts will be 22.5.
Bigboy49 is offline   Reply With Quote
Old 12-29-2013, 07:45 PM   #4
Rewards Points: 12,830
A picture of what your trying to work around would be great.
Old 12-29-2013, 11:06 PM   #5
Rewards Points: 616
big boy is right if holding trim up the way it goes on the wall.
try a crown molding cutting jig
milescraft, kreg,or bench dog
http://www.milescraft.com/products/i...5-crown45.html
http://www.kregtool.com/CrownPro-Prodview.html
http://www.rockler.com/search/go?w=c...cutting%20jigs
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 12-30-2013, 09:04 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
are you talking about a outside corner that has bullnose corner bead. if thats the case depending on the radius of hte corner bead it may need to be done as a 3 pc assembly or a 4pc.. in order to make the turn around the corner
this is the theory.. if your using whats called sprung crown the only difference is how you hold hte crown at the saw.. hes using hot melt glue because hes using foam crown. if your using wood use wood glue
woodworkbykirk is offline   Reply With Quote
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
Crown molding inside bay window Dieter Carpentry 7 10-03-2010 07:23 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Cutting bullnose crown molding... jaysen Carpentry 1 09-22-2009 01:12 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
