How To Cut A 6x6 Timber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 08:57 PM   #1
How to cut a 6x6 timber
The title says it all. I know it sounds wierd but a friend and I are building a retaining wall using 6x6 timbers. Everything seemed to be going good until we had to cut a timber. Circular saw doesn't cut all the way through, even cutting all sides. Any ideas? Thanks!
sleep is offline   Reply With Quote
Old 04-20-2009, 09:37 PM   #2
Chain saw
Old 04-20-2009, 09:43 PM   #3
Registered User
Rewards Points: 4,936
So you don't have access to a chain saw, reciprocating saw, hand saw, hack saw, router, or back saw?
You must have a drill, to pin the timbers with? Use the circular saw to cut a 2" (or however wide your drill motor front case is) notch in the beam, unless your drill bit is long enough. Clean out notch with a chisel, screwdriver, adz, etc. Drill a couple of holes through the remaining stock to weaken, roll onto rock, block, or beam, it should break. Clean up cut with a chisel, router, shovel, or toe-nail clippers. Be safe, GBAR
Old 04-21-2009, 12:17 AM   #4
Rewards Points: 150
8 -1/4 inch blade, worm drive saw, Make the first pass then flip it over, connect your first saw cut with a pencil then make the second cut. If you try to lay out the whole cut before you do the first cut you'll never make them meet for a clean cut.
Rent this if you can't buy one.
James Con is offline   Reply With Quote
Old 04-21-2009, 09:07 AM   #5
Thanks guys. I do have a drill and a hand saw. I was just looking for a more time effective method for cutting timbers. And a way to keep the cuts looking like they are factory ends.
Old 04-21-2009, 09:25 AM   #6
the Musigician
DangerMouse's Avatar
cut all 4 sides with circular saw as you have done, use hand saw to remove last 2" inside.
this is how i did it..... marked all 4 sides, cut one side, rolled once, continued in same groove, rolled again for third side, then last.
then i used my sawzall with a long blade to finish. i did not care about end appearances though.......
DM
Old 04-21-2009, 09:29 AM   #7
Rewards Points: 3,130
Makita makes a 16-5/16 inch circular saw (model number is 5402NA). I bought one to use in building my log home. It will cut your timbers easily in one pass. The saw is pretty expensive ($599 mew on Amazon) but maybe you can find somewhere to rent or borrow one.
Old 04-21-2009, 11:00 AM   #8
joed's Avatar
Rewards Points: 11,616
Cut all 4 sides then use the hand saw. Put the cut end inside so it will not be seen. Use a factory end where it is visible.
Timber retaining wall repair *Kennedy* Landscaping & Lawn Care 2 03-26-2009 07:02 PM
Laminate timber flooring over exsisting slate scott10 Flooring 6 06-20-2008 05:04 PM
Timber Slab table jesterchef Introductions 2 11-04-2006 02:17 AM
Hybrid Timber Frame 4powells Building & Construction 2 05-03-2005 10:14 AM
