How To Create Angled Cement Floor In Crawlspace - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 07:55 AM   #16
Stay-at-home GC
Also search "ground gutter" A fancy french drain.
I am putting one in now to address a steep slope to a foundation.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-27-2011, 08:23 AM   #17
Thank you for the thought (lowering water table) but as I mentioned at the outset, it's a fact. The home is 75 yards from a tidal inlet. The entire property is in a zone regulated by both local and state environmental agencies. Conventional remediation for crawlspace water does not work. It is a certainty that at certain times of the year there will be water coming into the crawlspace of my home and of all my neighbors homes. The best response to this that I've seen has been a well-contoured floor that causes all the water to drain to the sump pits...this is best because as soon as new water stops coming in, the space dries out fast (everyone uses dehumidifiers). I have standing water (because my floor does not route water to the pit) and that water has to evaporate (ie contribute to overall humidity) to leave. I want to pump it out, not remove it from the air.
MichaelTP is offline   Reply With Quote
Old 04-27-2011, 09:29 AM   #18
Getting There
MecGen's Avatar
Hi Micheal
I used a die grinder and 3 inch cutting wheels to channel a "ditch" in my concrete, moving standing water to a drain. I would not do it again.
#1 took HOURS, dirty job, full face mask, hands vibrate for hours after.
#2 you still have to angle the pitch of the ditch, as well make it deep enough as not to have standing water in the ditch itself (is that clear?) lots of fiddling around, grinding here, just to make another high spot there.
#3 my ditch gets plugged/blocked on a weekly basis by dirt and debris.
IMHO...Cut a hole in the middle of the lake and put in a sump pump, or use a cement quick saw, cut a 2 inch wide track completely through the slab, put in a 2 inch abs pipe, cut in half or drilled will holes, sloped/graded properly to the area you want.
Not too many low cost solutions only band aids, standing water sucks
Good luck
Frank
MecGen is offline   Reply With Quote
Old 04-27-2011, 10:52 AM   #19
Stay-at-home GC
If there is truly no way to lower the water table, that would be my suggestion as well.
Sump pump under the puddle and enough french drains around it to funnel water to it.
Cutting into wall to create a 24" tall by 15' wide crawlspace. Chesnut9 Building & Construction 4 11-21-2010 06:08 PM
Cement board for crawlspace skirting? IfItAintBrokeFixItAnyway Building & Construction 12 09-29-2010 07:43 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
