How To Creat Complex Curves With Wall Materials - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 08:24 PM   #1
Rewards Points: 342
Question
How to creat complex curves with wall materials
I have a small wall area where I need to create a complex curve. What kind of materials and techniques are available to do this?
tripower is offline   Reply With Quote
Old 03-01-2009, 10:04 PM   #2
Old School
Willie T's Avatar
I think you're gonna hafta be a whole lot more detailed than that. You know what you need to do, but we have no idea whatsoever.
Willie T
Old 03-02-2009, 06:53 AM   #3
Make top/bottom plates from plywood, curved as needed, fill in with standard studs. Then 2 layers of 3/8 drywall wetted on both sides. It will be bendable enough to fit most curves. For really tight curves, use layers of 1/4" drywall.
Old 03-02-2009, 08:17 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
http://www.flexc.com/
Tom Struble is offline   Reply With Quote
Old 09-16-2010, 08:07 PM   #5
Curves in drywall
Here is an easy alternative - premade drywall corners. Install and finish just like drywall but way less hassle.
How to creat complex curves with wall materials-painted-drywall-003.jpg   How to creat complex curves with wall materials-new-drywall-006.jpg
fulcrum1 is offline   Reply With Quote
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
retaining wall luv2hunt Landscaping & Lawn Care 1 05-02-2008 07:45 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
