How Could We Mount Plant Hanger On An Aluminum Post? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 07:15 PM   #1
Rewards Points: 77
How could we mount plant hanger on an aluminum post?
I have been asked to find a way to mount a plant hanger post or hook off the side of an aluminum column that holds up our patio roof.
I AM AT A LOSS OF HOW TO DO THIS.
Does anyone have any ideas?
The only thing that I can think of would be to locate a strip of metal behind the aluminum (if that is even possible to do) or possibly use butterfly bolts. Does anyone know if or whether either of these will work? Any better ideas?
Thanks!
1655graff is offline   Reply With Quote
Old 07-25-2009, 09:59 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
  • How wide is the Al column? 2'?, 4"?
  • Is the column embedded in concrete?
  • What is your Location? wind storms? tornadoes?
  • Can the Al post be replaced with a 4x4?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-27-2009, 05:59 PM   #3
Rewards Points: 77
Thanks, let me see If I can answer your questions
about 3.5" and is square
No. It is bolted to the concrete and to the roof it supports.
Location = on a ridge in the East Bay across from Redwood City (San Francisco Bay Area).
Prevailing winds = typically breezy, some stronger gusts. No tornadoes. Typical and rather infrequent wind storms come from the hills. Direction from sea/bay are most frequent & are the ones that would impact this structure the most since it is sheltered from Santa Ana winds (direction from the hills) by the house.
I've not considered that, but the enclosed section of the patio (also under the same roof) is supported by redwood 5x5's. And yet, replacing the Al columns is a little more work than I was thinking of doing.
BTW, I just had another idea: using a couple of strips of aluminum banding. But where would I find it and the tool to tighten it?
Old 07-27-2009, 06:16 PM   #4
I would suggest that a worm drive hose clamp would be used. These can be purchased in various lengths and if greater length is required than is available, they can be 'daisy' chained to make them longer!
Using these won't effect the structural integrity of the post!
Old 07-27-2009, 06:16 PM   #5
long island, NY
my initial instinct is to not pierce the metal... what if your friend doesn't want the hanger there in a few years?
What about suspending it from the rafters of the patio roof?
diy'er on LI is offline   Reply With Quote
Old 07-27-2009, 06:24 PM   #6
Rewards Points: 77
That might work except the patio roof is interlocking 'U's of Aluminum. they are held together by self-driving screws at the interlocking overlap of the capital (top lateral lines) of adjacent 'U'.
Old 07-27-2009, 06:26 PM   #7
Rewards Points: 77
That's along the lines of what I was thinking about when I thought of "banding." Except perhaps, do those bands conform to squares (like these columns)?
Old 07-27-2009, 07:00 PM   #8
I used this method to place a screened cap on my fireplace chimney opening and it worked well. Although the ceramic flue did have rounded corners.
Right angle bends can be made in hose clamps. So with care, they should able to be fitted to your post.
Perhaps if you made a point of using 4 clamps (one per side) it could be done neatly!
Newel post repair for dummies Zarack Carpentry 17 06-20-2011 05:43 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 03:39 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
How To: Post Nathan Getting Started With DIY Chatroom 0 07-04-2008 04:08 PM
