Old 06-23-2011, 03:02 PM   #1
how to correct old problem roof/wall
Hello,
I recently found out that parts of my roof aren't flashed correctly and I would like to address this issue now.
The main culprit is where the roof butts up to an exterior wall.
I know I have to add step flashing but what is the best way to do this now.
The roof is newer and the wall has wood clapboard with vinyl siding over it. Do I need to get the flashing undr the wood clapboard? Does it need to be attached?
Any advice or tips would be great.
bfan781 is offline   Reply With Quote
Old 06-23-2011, 04:40 PM   #2
Was the new roof put over and older one or was the roof stripped down to the sheathing?
If it went over the old roof, the original flashing is probably still there.
Is there an issue with leaks in the area?
What's under the current vinyl? did they put foam insulation?
Ron
B. Franklin 1759
Whirlpool refrig. problem ken1415 Appliances 138 05-04-2013 05:49 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
