How To Close Off Basement Ceiling Joist Cavities? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 10:50 AM   #1
Jason M.
How to close off basement ceiling joist cavities?
Good morning all,
I need some suggestions on a project that I've been working on. I'm closing off a quarter of my basement for a playroom for the rugrat. When we bought the house, one wall was already in place as a divider for the laundry area. I've already framed the second wall and run the electrical (wires only, nothing is hooked up). I also have painted the rafters white to brighten up the space. The wall I framed runs perpendicular to the joists, so I'm left with open cavities above the top plate of the wall. I'm looking for suggestions on how to close off that space. I do not want to install a ceiling of any sort. I don't need anything fancy and definitely need something inexpensive, but don't want it to look like junk. I debated stapling the rolled batt insulation with the paper backing. I think that'll look like junk. I've also though of running leftover drywall up there or cutting foam board insulation panels to fit and painting them. The new room is heated, but we left the cinder walls exposed, so there will be some temperature fluctuation. I mention this because it's not necessary that the solution be airtight. Although I wouldn't mind that.
Let the brainstorming begin.
Thank you in advance!
letzjam11 is offline   Reply With Quote
Old 02-05-2013, 10:54 AM   #2
MarginallyQualified
Rewards Points: 2,464
What brinstorming?
Put up a drop ceiling.
Old 02-05-2013, 11:15 AM   #3
"You can do anything"-Mom
brockmiera's Avatar
Good morning all,
Just put in blocking of the same size material as the joist. If you have a 2x10 joist spaced on 16" centers then use a 14.5" long piece of 2x10 and nail it in place.
If you don't have a solid joist then post a picture and I'm sure we can figure out the best way.
brockmiera is offline   Reply With Quote
Old 02-05-2013, 11:45 AM   #4
Jason M.
Thanks Tarheel, but I specifically stated that I did not want a ceiling installed. I've already taken the steps and money to paint the exposed joist ceiling.
Brock, not sure why I didnt' think of that. That's something to definitely consider. Thanks.
If you've got other ideas, I'd love to hear them!
Old 02-05-2013, 11:45 AM   #5
Rewards Points: 1,418
Install a wide board such as a 1x12 horizontally, against the wall, and on the underside of the joists, to act as a "partial ceiling" to hide the open spaces above the wall top plate.
Add insulation of any kind filling the spaces between the joists and above the board, optionally set back from the outer edge of the board.
(hindsight or eavesdroppers only) The entire "rafter" area will look more elegant with everything painted flat black instead of white.
The Following User Says Thank You to AllanJ For This Useful Post:
concretemasonry (02-05-2013)
Old 02-05-2013, 11:52 AM   #6
brockmiera's Avatar
Thats the beauty of this board!
If you can post a picture it would help.
What does your son/daughter like? Whatever you put up there you can paint animals on, or their initials, or things that will make them feel like its their space.
Old 02-05-2013, 11:59 AM   #7
brockmiera's Avatar
FYI Exposed insulation board is a fire hazard so dont use that.
The Following User Says Thank You to brockmiera For This Useful Post:
letzjam11 (02-05-2013)
Old 02-05-2013, 12:10 PM   #8
Jason M.
Picture coming in an hour or two.
AllanJ - Do you mean to install the 1x12 similar to my top plate and but it up against the top plate of the wall? Essentially creating a "shelf" in the joist cavities?
Old 02-05-2013, 01:16 PM   #9
Jason M.
Pay no attention to the studs that I need to install because I forgot to account for drywall attachment.
Old 02-05-2013, 01:23 PM   #10
brockmiera's Avatar
I personally think wood blocking or drywall is going to be your best bet.
I think if you install blocking directly over that wall in the joist cavity you can remove the other blocking thats in place. Hopefully someone on here can verify that but it makes sense to me. If your sheer or torsional forces are greater than that I'm sure you'd have had big problems by now.
Old 02-08-2013, 06:00 PM   #11
brockmiera's Avatar
So what did you end up doing?
Old 02-09-2013, 12:27 AM   #12
Jason M.
Nothing yet. I'm still debating.
Out of curiosity, why would the foam insulation be a fire hazard, but rolled insulation not be? I spoke to a few friends who have finished their basements (or parts of them) who painted foam board insulation and filled the area between the joists.
Old 02-09-2013, 01:13 AM   #13
Rewards Points: 12,882
Read what it says right on the panels there flamable and they give off toxic fumes as they melt.
Even even check the prices on foam?
You could buy two sheets of sheetrock for the price of one panel and be code compliant with sheetrock.
Old 02-09-2013, 08:25 AM   #14
Jason M.
Sounds good. Thanks. I hadn't physically looked at them, just thought it was an idea. Now it's not an idea.
Old 02-09-2013, 07:45 PM   #15
brockmiera's Avatar
You can use them you just have to cover them up with drywall. It will look the same as with wood blocking just more expensive.
Tags
basement , insulate , joist
Strengthen Ceiling Joist cocxanh Building & Construction 14 11-07-2012 02:27 PM
Ceiling joist KShirriff Building & Construction 27 10-15-2012 08:48 PM
Basement Finishing, Where to start? Ceiling? swarren Remodeling 8 01-08-2012 06:27 PM
Bridging a ceiling Joist dR3w Building & Construction 1 01-05-2011 04:36 PM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 07:58 PM
