-   -   How to close off basement ceiling joist cavities? (http://www.diychatroom.com/f19/how-close-off-basement-ceiling-joist-cavities-171098/)
letzjam11 02-05-2013 10:50 AM
Good morning all,
I need some suggestions on a project that I've been working on. I'm closing off a quarter of my basement for a playroom for the rugrat. When we bought the house, one wall was already in place as a divider for the laundry area. I've already framed the second wall and run the electrical (wires only, nothing is hooked up). I also have painted the rafters white to brighten up the space. The wall I framed runs perpendicular to the joists, so I'm left with open cavities above the top plate of the wall. I'm looking for suggestions on how to close off that space. I do not want to install a ceiling of any sort. I don't need anything fancy and definitely need something inexpensive, but don't want it to look like junk. I debated stapling the rolled batt insulation with the paper backing. I think that'll look like junk. I've also though of running leftover drywall up there or cutting foam board insulation panels to fit and painting them. The new room is heated, but we left the cinder walls exposed, so there will be some temperature fluctuation. I mention this because it's not necessary that the solution be airtight. Although I wouldn't mind that.
Let the brainstorming begin.
Thank you in advance!
TarheelTerp 02-05-2013 10:54 AM
What brinstorming?
Put up a drop ceiling.
brockmiera 02-05-2013 11:15 AM
Good morning all,
Just put in blocking of the same size material as the joist. If you have a 2x10 joist spaced on 16" centers then use a 14.5" long piece of 2x10 and nail it in place.
If you don't have a solid joist then post a picture and I'm sure we can figure out the best way.
letzjam11 02-05-2013 11:45 AM
Thanks Tarheel, but I specifically stated that I did not want a ceiling installed. I've already taken the steps and money to paint the exposed joist ceiling.
Brock, not sure why I didnt' think of that. That's something to definitely consider. Thanks.
If you've got other ideas, I'd love to hear them!
AllanJ 02-05-2013 11:45 AM
Install a wide board such as a 1x12 horizontally, against the wall, and on the underside of the joists, to act as a "partial ceiling" to hide the open spaces above the wall top plate.
Add insulation of any kind filling the spaces between the joists and above the board, optionally set back from the outer edge of the board.
(hindsight or eavesdroppers only) The entire "rafter" area will look more elegant with everything painted flat black instead of white.
brockmiera 02-05-2013 11:52 AM
Thats the beauty of this board!
If you can post a picture it would help.
What does your son/daughter like? Whatever you put up there you can paint animals on, or their initials, or things that will make them feel like its their space.
brockmiera 02-05-2013 11:59 AM
FYI Exposed insulation board is a fire hazard so dont use that.
letzjam11 02-05-2013 12:10 PM
Picture coming in an hour or two.
AllanJ - Do you mean to install the 1x12 similar to my top plate and but it up against the top plate of the wall? Essentially creating a "shelf" in the joist cavities?
letzjam11 02-05-2013 01:16 PM
1 Attachment(s)
Pay no attention to the studs that I need to install because I forgot to account for drywall attachment.
brockmiera 02-05-2013 01:23 PM
I personally think wood blocking or drywall is going to be your best bet.
I think if you install blocking directly over that wall in the joist cavity you can remove the other blocking thats in place. Hopefully someone on here can verify that but it makes sense to me. If your sheer or torsional forces are greater than that I'm sure you'd have had big problems by now.
brockmiera 02-08-2013 06:00 PM
So what did you end up doing?
letzjam11 02-09-2013 12:27 AM
Nothing yet. I'm still debating.
Out of curiosity, why would the foam insulation be a fire hazard, but rolled insulation not be? I spoke to a few friends who have finished their basements (or parts of them) who painted foam board insulation and filled the area between the joists.
joecaption 02-09-2013 01:13 AM
Read what it says right on the panels there flamable and they give off toxic fumes as they melt.
Even even check the prices on foam?
You could buy two sheets of sheetrock for the price of one panel and be code compliant with sheetrock.
letzjam11 02-09-2013 08:25 AM
Sounds good. Thanks. I hadn't physically looked at them, just thought it was an idea. Now it's not an idea.
brockmiera 02-09-2013 07:45 PM
You can use them you just have to cover them up with drywall. It will look the same as with wood blocking just more expensive.
