How Can You Identify A Drill Bit Or Saw Blade By Looking At It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 06:34 PM   #1
How can you identify a drill bit or saw blade by looking at it?
Anyone know of any way to identify a blade simply by looking at it to see its intended use?
gomerpyle is offline   Reply With Quote
Old 06-11-2009, 07:38 PM   #2
the Musigician
DangerMouse's Avatar
yes...simply by looking at it.... usually works for me, what exactly are you referring to?
steel-vs.-wood-vs.concrete drill bits, or what?
plywood-vs.-crosscut-vs.-ripping blades?
DM
Old 06-11-2009, 07:59 PM   #3
Remodeling Contractor
saw blades are used for different tasks based on the number of teeth and the angle they are set. Very easy to tell which is for what purpose when you know how they cut.
Old 06-11-2009, 09:45 PM   #4
Rewards Points: 5,336
post removed
Gomer said:
duhhhhhhhhhhhhhhh
Exactly!
Ron
Last edited by Ron6519; 06-13-2009 at 12:59 PM. Reason: unnecessary and inflammatory post removed
Old 06-13-2009, 12:10 PM   #5
How to identify drill bit or blade
What i meant is how do you thre material it is meant for by looking at it?
Old 06-13-2009, 12:11 PM   #6
duhhhhhhhhhhhhhhh... i meant the material it is meant for!
Old 06-13-2009, 07:45 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
bits for concrete often have a carbide "chip" in the end, this chip or chips is the widest part of the bit, and the flutes have a hi-low pattern, like a tapcon screw. wood bits often have a tight spiral on the very tip, and a wide flute pattern that starts tight and gets wider. steel bits usually have a split tip, with a consistent flute from end to end.
these are general guidelines, but there are many exceptions. it is easy to figure out as you get used to it
the basic guideline for sawblades is the more teeth per inch, the harder the material it is meant for.
think of the coarse teeth on a hand crosscut saw meant for wood, versus the hundreds of fine little teeth on a hacksaw blade used on steel. Plenty of exceptions, but this is a good rule to start with
Mr Chips is offline   Reply With Quote
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 01:58 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
