Old 09-30-2008, 11:22 PM   #1
yummy mummy's Avatar
How can I tell if my taping is good enough?
I have pretty much finished taping my drywall, and I have sanded and I think it looks pretty good to me.
I have put a light from an angle on the walls and it looks pretty good to me.
How would I know for sure before I put the primer on?
Is there a drywall primer that is more "hiding" than another?
yummy mummy is offline   Reply With Quote
Old 09-30-2008, 11:48 PM   #2
Put a square across the joint,,,or a long drywall knife,and strong light behind and see what you see. Put bright light close to wall and look both ways
4just1don is offline   Reply With Quote
Old 10-01-2008, 12:24 AM   #3
Moderator
Termite's Avatar
Glossy paints will show the flaws more than flat paints will.
The light trick works as well as anything I know. Put your head to the wall you're checking and look along the wall, not right at it.
Old 10-01-2008, 09:14 AM   #4
thanks for the responses.
KC, I do not plan on using high gloss, so I am hoping that it will turn out ok.
I have put the light to it and it looks good to me.
What I may do is prime one wall and see how it looks.
Old 10-01-2008, 10:16 AM   #5
Home Remodeler
I find the primer will show the defects. You can still touch them up over the primer.
mikey48 is offline   Reply With Quote
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Good equipment to use for carpet cleaning? Beth777 General Discussion 5 08-29-2008 09:16 PM
Taping inside corners....one side at a time? yummy mummy Building & Construction 10 07-23-2008 03:23 PM
What would be good quality paint kenny357 Painting 13 06-07-2007 02:36 AM
