-   -   How can I tell if my taping is good enough? (http://www.diychatroom.com/f19/how-can-i-tell-if-my-taping-good-enough-29077/)
yummy mummy 09-30-2008 10:22 PM
I have pretty much finished taping my drywall, and I have sanded and I think it looks pretty good to me.
I have put a light from an angle on the walls and it looks pretty good to me.
How would I know for sure before I put the primer on?
Is there a drywall primer that is more "hiding" than another?
4just1don 09-30-2008 10:48 PM
Put a square across the joint,,,or a long drywall knife,and strong light behind and see what you see. Put bright light close to wall and look both ways
Termite 09-30-2008 11:24 PM
Glossy paints will show the flaws more than flat paints will.
The light trick works as well as anything I know. Put your head to the wall you're checking and look along the wall, not right at it.
yummy mummy 10-01-2008 08:14 AM
thanks for the responses.
KC, I do not plan on using high gloss, so I am hoping that it will turn out ok.
I have put the light to it and it looks good to me.
What I may do is prime one wall and see how it looks.
mikey48 10-01-2008 09:16 AM
I find the primer will show the defects. You can still touch them up over the primer.
