How Can I Support Joist After I Cut It For Waste Pipe? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 02:16 PM   #1
How can I support joist after I cut it for waste pipe?
I am trying to add a bathroom to my attic. The only spot to run the pipe is next to the chimney. I have looked at every possible location to run the pipe and the only options I have is this spot or go down the laundry chute. We still use the chute and if we used it to run a waste line through the bathroom in the attic would not be where we want it. Running the pipe next to the chimney will be pretty easy except for in the basement. Where the pipe comes down from is right on top of a joist.
http://postimage.org/image/eg69u26ud/
http://postimage.org/image/49sh9j7q7/
http://postimage.org/image/sxso8xk1l/
Here is some pictures. I was going to try and do this
http://postimage.org/image/3s6vn1ur7/
But I can't because the chimney is on the other side
What can I do? Thanks in advance
Ellington66 is offline   Reply With Quote
Old 03-17-2013, 04:54 AM   #2
DIY staff
Rewards Points: 7,174
Moved to building and construction------
Old 03-17-2013, 07:16 AM   #3
Rewards Points: 1,216
No way would I cut that old joist for that pipe. I would try to offset around it or figure out something else. Looks like a real old place , got to be careful what you cut and what reason.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-17-2013, 08:30 AM   #4
Rewards Points: 722
I think you can follow the diagram you posted. Usually you need to double up on the joists to install the headers across, but the area around the chimney rarely supports any weight. Just make sure the full joist away from the chimney is above a dead space, or if you can, sister 2x6 or full width 3/4 plywood, spanning 8' center.
The gray electrical cable should be replaced. I think it is a kind of cloth jacketed romex, and my personal experience is that the insulation will crumble on you if you do any work on them.
carpdad is offline   Reply With Quote
Old 03-17-2013, 09:09 AM   #5
Nope no cutting that! Time to use 22 degree or 45's to offset it. don't always have to be a strait line.
RTC_wa is offline   Reply With Quote
The Following User Says Thank You to RTC_wa For This Useful Post:
COLDIRON (03-17-2013)
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
attic joist support kimallen123 Building & Construction 3 05-04-2010 12:31 PM
