How Can I Grind Down The Asphalt? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 04:17 PM   #1
How can I grind down the asphalt?
The asphalt ramp to my storage shed frost-heaved.
But it did not go back down in the summer.
Now I can't open the doors.
furjaw is offline   Reply With Quote
Old 03-04-2010, 04:33 PM   #2
Rewards Points: 1,016
How much does it need to go down?
Heat and tamp it down maybe - I did this with a asphalt speed bump that was too high and abrupt in coutour.
The Following 2 Users Say Thank You to vsheetz For This Useful Post:
drtbk4ever (03-04-2010), Willie T (03-04-2010)
Old 03-04-2010, 06:54 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,.... It might take awhile, but a 4" anglegrinder will Do the job....
Old 03-04-2010, 07:22 PM   #4
Old School
Willie T's Avatar
Sheets has it right. Asphalt will melt and flow. I have a friend who has a driveway rejuvenation business. He places molds on old, cracked and stained asphalt drives. They flow to the shape of the molds under heat, and they look like a million dollars when he's done.
Check THIS out !
Willie T
Old 03-04-2010, 07:39 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Check THIS out !
that's pretty cool. It's like stamped concrete.
Old 03-05-2010, 11:31 AM   #6
If you have ever had a motorcycle and on a hot day parked it via the side stand on asphalt, only to come back and find the bike laying on it's side... shows how easy it is to soften asphalt...
Old 03-05-2010, 08:41 PM   #7
nap
You talking to me?
nap's Avatar
Check THIS out !
kind of curious as to how it's done. The only thing I can think of is using a metal mold for the pattern, a smallish roller, and something to heat the asphalt.
any idea how it is actually done?
Old 03-06-2010, 10:03 PM   #8
A half inch should do it.
I bought a propane torch from Home Depot a couple of years ago and it would not stay lit!
Old 03-07-2010, 03:08 AM   #9
Rewards Points: 4,796
we'd pick a stone hammer & cold chisel,,, diamond blade'd work IF it were conc but asphalt cement flows when its warm & you'll just have a gummy mess on your hands,,, IF its just a small heav'd crk edge, i'd hammer ir back down if possible,,, you can rent a gas-power'd scarifier ( $ 350 d here in suburb atl which's why we own a couple ) - 5 min work,,, elec chipping gun w/bushing tool would also work !
sorry for the delay - just got back from the shore & some golf
stadry is online now   Reply With Quote
Old 03-07-2010, 12:11 PM   #10
I would 'pick' the heaved asphalt out of there! Then dig out some gravel to lower the general area, the repair the asphalt with a bag of 'cold' pack from the building center!
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
Seal off area between rough opening and asphalt felt with spray foam? kooshball Building & Construction 5 12-14-2009 11:25 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 05:51 PM
Asphalt Question javan General DIY Discussions 5 07-16-2008 06:38 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
