How Can I Fix This Loose Toiler Paper Holder? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 07:51 PM   #1
Question
How can I fix this loose toiler paper holder?
Hi,
I have no experience in fixing things around the house. In my bathroom, the toiler paper holder has come out of the wall (see photo below). What can I do to re-secure this & what would I need to purchase? Thanks!
pajhonka is offline   Reply With Quote
Old 07-22-2009, 08:43 PM   #2
Use a toggle bolt
http://www.tpub.com/content/construc...14043_99_2.jpg
or remount where you can hit at least one stud.
Old 07-22-2009, 09:45 PM   #3
Household Handyman
Rewards Points: 1,408
I see one of those big, white, plastic, screwlike thingy's, they sell and say "will hold up a battleship", but won't hold up a toilet paper holder will they? Unfortunately, the hole this thing left may be too big for a toggle bolt the correct size to help you. You could get a toggle bolt and try, let's hope it works. If this doesn't work, the you may be into placing a piece of 2 x 4 between two studs, behind the sheetrock, so you have something to really anchor the toilet paper holder to. If you are not a DIY person, maybe you can find a good Handyman type person who can do this for you at reasonable cost. OR, post back on this and we will walk you through this job, and reward ATTABOYS also. Good Luck, David
Old 07-22-2009, 09:59 PM   #4
If you're a woodworker you could make a rect. plate with beveled edges that the paper holder is fastened to, and then the plate fastens to the wall with four fasteners of any kind.
This spreads the force and resists the yanking loads and torqueing that these things sometimes see.
Old 07-23-2009, 01:21 PM   #5
when my anchor fell out, i usually replace it with the toggle version
http://www.itwbuildex.com/ezprod.htm
homedepot used to sell it, but replaced the made in usa versions with made in taiwan/china ones nowadays
ufokillerz is offline   Reply With Quote
Tags
loose fixture , sheetrock , toilet paper holder
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 03:48 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
