How To Calculate Joist Spacing??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 11:03 AM   #1
Rewards Points: 156
How to calculate joist spacing???
Ok I'm a math idiot...seriously. The scenario is that I want to space 4 joists evenly between two walls but for the life of me, I cannot calulate the measurements. The beams will be exposed so that is why I want them to look even. I've tried measuring the middle point and working from there but nothing looks right. Is there a simple calculation that I can use? Right now I'm just trying to eyeball it but I really want it to be perfectly even. My brain just won't work.
jayp is offline   Reply With Quote
Old 06-05-2008, 11:28 AM   #2
Registered User
Termite's Avatar
Your on-center spacing would be the face-to-face measurement of the walls divided by 5, give or take. Beam thickness will end up making the outer two off a little, but you can adjust.
Old 06-05-2008, 12:57 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Take your total width. Subtract the total thickness of ALL the joists. Divide the remainder by the number of Joist CAVITIES. Add the thickness of one joist and that will give you the centers.
Example:
8 foot space= 96 inches
7 joists @ 1.5 = 10.5 inches
96 minus 10.5=85.5
85.5 divided by 6 cavities= 14.25 inches between each joist
14.25 plus 1.5=15.75 inches from center to center
The Following User Says Thank You to Maintenance 6 For This Useful Post:
jack45870 (10-17-2014)
Old 06-06-2008, 06:17 AM   #4
Rewards Points: 156
Thanks!
Thanks!
Old 10-16-2014, 02:10 PM   #5
Rewards Points: 2
Spacing calculator
Than this android application is the solution for you: SPACING CALCULATOR developed by SM.
stevuliak1 is offline   Reply With Quote
Old 10-16-2014, 02:29 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Are they joists or beams, you mentioned both.
You said that they are exposed so I assume they seen from below?
Will they then be floor joists?
If so, what kind of load will they be supporting?
Bedroom of something else?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 10-16-2014, 03:03 PM   #7
Hopefully he's figured it out since 2008.
Old 10-16-2014, 03:15 PM   #8
AndyGump's Avatar
Rewards Points: 684
Doh!!!
Thanks.
First time in a long time I not looked at the date when responding.
Andy.
Old 10-16-2014, 07:12 PM   #9
Rewards Points: 454
That's funny,maybe he's rebuilding by now.
scottktmrider is offline   Reply With Quote
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
sister a joist Jack Hass Carpentry 7 06-19-2007 05:39 PM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 02:02 PM
