How To Build A Doghouse Roof Over Door? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 03:48 PM   #1
Rewards Points: 308
How to build a Doghouse roof over door?
What materials would I need to build something like this?
smokey847 is offline   Reply With Quote
Old 03-11-2012, 03:58 PM   #2
Rewards Points: 528
A material list???
framer52 is offline   Reply With Quote
Old 03-11-2012, 04:14 PM   #3
Rewards Points: 308
Precisely.
Old 03-12-2012, 02:17 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
The reality is....if your asking that type of question...then your most likely attempting something that you are not qualified to do.
It's about par to seeing a picture of a turkey and asking what you need to buy to bake one.
But...to somewhat answer your question.....you need wood, nails and some shingles. Depending on the exact design, you might need some screws as well.
ddawg16 is online now   Reply With Quote
Old 03-12-2012, 03:19 AM   #5
Superp!!!
roofing contractor
smithdavid is offline   Reply With Quote
Old 03-12-2012, 01:57 PM   #6
Rewards Points: 308
By the nature of this forum (a do-it-yourself outlet), I figured it was a plausible question. I can build the roof no problem, but am looking for any input from someone who has had experience building one before for any tips I may not be thinking of. Thanks anyway.
Old 03-12-2012, 06:45 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 674
Send a message via Skype™ to AndyGump
I guess you could call it a plausible but, it was simply too vague.
I suppose you would need roofing material, under-lament, lumber, nails, sheathing, posts, hardware, concrete, flashing, paint and primer, caulk, putty, screws, plans for permits, etc.
In what quantities I have no idea.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
