-   -   How to build deck stairs like this (http://www.diychatroom.com/f19/how-build-deck-stairs-like-144828/)
djinlondon 05-25-2012 02:03 PM
1 Attachment(s)
I want to build stairs for my deck that look like the attached image. The stairs will come off the deck down onto the grass. I've looked at different manuals, guides, websites, etc. but I cannot find instructions on building these and what the underlying frame looks like.:confused1:
Willie T 05-25-2012 02:22 PM
Do a little thinking about it. It's really very simple. You may be trying to over-complicate things.
It's just a deck on top of steps... and there are a couple of ways to accomplish it.
Gary in WA 05-25-2012 11:18 PM
The 2x6 frame elevated 1-1/2"-- 2-1/4" gives a neat effect. Just remember to install a handrail though, 4 or more risers: http://publicecodes.citation.com/ico...011_par016.htm
Keep you safe: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
CrossWorks 05-26-2012 05:11 AM
Lights in between those steps would complete the effect!
I'm sure that there are vertical supports within the deck frame across the width of each step, and the 4x4 post help support the ledger for each step level.
Have those in place and you'll achieve your goal. And as GBR stated, if you have 4 or more risers you'll need a rail.
kwikfishron 05-26-2012 06:38 AM
199 Attachment(s)
I don't see how those stairs would pass.
The treads coming down the ends look to be less than 10"
Where's the nosing? 3/4" min to 1 1/4" max.
CrossWorks 05-26-2012 07:22 AM
I agree, those certainly do not meet the min requirement on the sides but that can be easily fixed. As for nosing, I believe that may be a required aspect for certain city districts, but I'm sure is not required for every deck out there.
djinlondon 05-27-2012 11:04 AM
I'm not so much worried about a railing as I will only have 2 risers (3 at most). But the question remains... how would you frame this?
Tham 05-27-2012 11:42 AM
2x8 box on a 2x8 box on a 2x8 box on a 2x8 box. 2x6 decking and wrap. That'll give you that floating look.
I've done this.
Tham
hand drive 05-27-2012 11:54 AM
^ yup, the floating look is achieved by raising the stair risers off of the stair treads and maybe painting the framing behind it all a black color. if you were to stick your head down at eye level and look up into the stair system in the pic there would be framing behind the decking :)
you could lay all of the dimensions out on the deck band to determine your stair layout and then plumb down to the dirt, the stairs' sides will be the same tread width as the front so each consecutive step landing is two tread widths smaller.
Willie T 05-28-2012 03:13 PM
3 Attachment(s)
Here it is in one form. (The very simplest)
I've included it in SKP so you can open it and see how it goes together.
Of course, the ripping measurements would be up to you to figure out.
If you wanted to 45 the corners, naturally, you'd need additional bracing.
