How To Build A Carring Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 10:32 AM   #1
How to build a carring beam
I hav e an older cottage which is measures 22 x 30 feet. The floor joist are rough 2x6 spaced at 16 inch centers.There are 5 carring beams running the 22 ft span , made of 4 2x8 laminated together. I want to jack up the cottage and run 3 beams the 30 foot lenght .Question is what can I make them out of ( would prefer to laminate pressuretreated lumber together ) and what spacing would I need for the supports.
Thanks any help would be appricated.
trapper1953 is offline   Reply With Quote
Old 06-16-2010, 02:07 PM   #2
1
2
1 each joist is 30' long?
2 more than 2 beams supporting the end of each joist is very complex to calculate but if you know what wood it is and what the deflections are between supports the whole thing might be reverse-engineerable. Knowing the dead weight of the whole cottage is probably useful.
Also try
http://civilengineerblog.com/forum/e...udents/page-1/
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
Need to build 10' beam, specs??? harleysilo Building & Construction 7 01-08-2007 08:11 AM
