Old 06-04-2012, 12:47 PM   #1
How to build a beam?
We are building a new home that is 32' by 76'. We need to build the main support beam to go the entire length of the house. We were thinking that staggering 2X12 boards would work, but we do not know what would be a good length to use and how short is too short of a span. Also is three 2x12's enough support with support posts in place every 16 feet?
akmills is offline   Reply With Quote
Old 06-04-2012, 12:56 PM   #2
joed's Avatar
You need an engineered beam. The length and what you use to make the beam is dependent on the span between supports.
You could probably get a one piece paralam or LVL or some other brand name. Talk to your lumber supplier.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 06-04-2012, 12:57 PM   #3
Super Moderator
Is there an architect involved here?
The size and span depends on the load that the house puts on the beam--how heavy is the house?
How many stories?
Have you got a general design drawn up?
Old 06-04-2012, 01:02 PM   #4
concretemasonry's Avatar
It must be engineered if you want stick built-up beam over multiple supports. I am sure an engineer would look at both steel and wood beam construction.
When you go to post location, have some idea of how you want to cut up the basement area, so the posts can be located for the future and not force you to relocate them later - big $$$ to put in posts at a different location.
Dick
concretemasonry is online now   Reply With Quote
Old 06-04-2012, 02:42 PM   #5
It was a dark and stormy
Yoyizit's Avatar
My 30'x30' basement has a hefty I-beam and a single 4" dia. post in the center. Consult a civil or mechanical engineer or an architect; you don't want to have to do this over.
Also, Lindeburg publishes books (possibly available in your local library) on studying for the PE exam for civil and mech. engineering. This solved problem might be in one of them.
http://www.google.com/cse?cx=partner...ing&gsc.page=1
Old 06-04-2012, 03:20 PM   #6
Framing Contractor
You need an architect or engineer to figure thus out for you. You cannot get this information on a DIY'er forum.
Joe Carola
Joe Carola is offline   Reply With Quote
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 12:50 PM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 07:20 PM
How to build a carring beam trapper1953 Building & Construction 1 06-16-2010 03:07 PM
Beam Construction kemp Building & Construction 4 09-14-2009 11:26 PM
