How Best To Block Up A Chimney Hole When Taken Fire Place Out - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2009, 11:18 AM   #1
How best to block up a chimney hole when taken fire place out
I have just removed all the fireplaces from a 2 up 2 down victorian house. I want to seal the holes with blocks and cement. However what about damp.Surely rain water will still come down the chimney and rest in the bottom of the fireplaces therefore creating damp behind the newly sealed holes. Is this a problem and if so how do I resolve it
AMT33 is offline   Reply With Quote
Old 03-04-2009, 02:33 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Take off the portion of the chimney that projects above the roofing. Cover with the same type of roofing after you have secured the support for the roofing. This will also eliminate the possibility of leaks between the chimney and the roofing.
concretemasonry is offline   Reply With Quote
Old 03-04-2009, 04:19 PM   #3
Or at least fashion a sheet metal cap for the top! its needs something to keep the rain and varmints out!
Old 03-04-2009, 05:57 PM   #4
Rewards Points: 95
If the chimney comes through the house and out the roof. I agree with concretemasonry. This would be the best way and later if you wanted to reuse the fireplaces you could rebuild the chimney with any brick you want since you will only see what is above the roof.
NJ Brickie is offline   Reply With Quote
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Fire Place / Wood Burning Stove Question fburke Building & Construction 1 12-27-2007 10:52 AM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 09:42 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
