How To Bend A Heavy Duty L Bracket? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 11:31 AM   #16
Bill Kearney
Rewards Points: 1,174
Originally Posted by jmsheldon View Post
I have an L bracket and I need to bend it to be 45 degrees instead of 90 degrees.
What is it you need this bracket to do? Could be you're using the wrong item to solve the problem.
Re-bending existing brackets is probably worse than just getting a flat piece of steel and bending it once. You greatly weaken the metal bending or hammering it.
So it really depends on what you want to do with it?
wkearney99 is offline   Reply With Quote
Old 03-03-2013, 11:33 AM   #17
Don't buy a step drill for this. Use a regular drill bit and feed it slowly, but clamp or screw down the bracket.
Dorado is offline   Reply With Quote
Old 03-03-2013, 12:46 PM   #18
Use two pipe wrenches to bind it!
Hardway is offline   Reply With Quote
Old 03-03-2013, 03:26 PM   #19
Rewards Points: 642
I find a spot on a garage slab that I don't mind chipping. I stand the ell on one leg and hit the other leg at the tip with 3 lb hammer. After little angle is established, I can hit it nearer the angle. If any part of the leg gets bent, straighten on 2x4.
carpdad is offline   Reply With Quote
Old 03-05-2013, 07:34 PM   #20
Handyman
brucem609's Avatar
Rewards Points: 79
First s few the bracket to a vertical stud that will not move. Have the side you want to bens to be the free side. Next, use a piece of lumber and pull open the L portion of the bracket. You can micro adjustit a little at a time.
brucem609 is offline   Reply With Quote
Tags
bend , bits , drill , metal , tools
Heavy Duty Casters BigJim General DIY Discussions 16 12-23-2011 04:48 PM
Heavy Duty Tools/For a Woman's Hands Sheila4467 General DIY Discussions 8 11-07-2009 02:30 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
Heavy Duty Tapcons terri_and_jj Building & Construction 1 02-24-2008 01:25 PM
Heavy duty garage shelving suggestions feign3 Carpentry 1 09-20-2007 10:07 PM
