How To Bend A Heavy Duty L Bracket? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 08:52 AM   #1
I have an L bracket and I need to bend it to be 45 degrees instead of 90 degrees. How can I do this without some serious tools?
The L bracket was not welded to be 90 degrees, it was bent.
I also need to open up one of the holes on it. Can I do this with regular drill bits? Thanks.
jmsheldon is offline   Reply With Quote
Old 03-03-2013, 09:19 AM   #2
Rewards Points: 13,270
Got a picture?
What's it going to be used for?
How thick is it really? And what's it made of? Heavy duty to you may not be the same thing as HD to me.
Old 03-03-2013, 09:23 AM   #3
The one I need to bend is 1-1/8" thick. The ones that I need to open up the holes of are 1-1/4" thick.
Old 03-03-2013, 09:26 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
1 1/8" thick metal would need an entire high rise building to sit on it to bend it. do you know a metal shop that can make the bracket that you need?
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
woodworkbykirk (03-03-2013)
Old 03-03-2013, 09:30 AM   #5
If those sizes are right that sure would be heavy duty.
I see no way a DIY is going to be bending that, even if you did there would be what's called elastic deformation. Which just means it would be no good once bent.
If I had to do this I would just have any machine shop make one up for me.
They can use a milling machine to mill the 22-1/2 deg angles or cut the plate on a horizontal band saw, dill the holes on a milling machine and weld the two plates together.
Old 03-03-2013, 09:52 AM   #6
Rewards Points: 220
i doubt they are over 1" thick. i bet they are over 1" in size. probably 1/16" thick.
still, your not bending that without some tools. i would cut and weld it, but i have the tools to do that. could also heat and bend, but i have the torches to do that also.
Fix'n it is offline   Reply With Quote
Old 03-03-2013, 09:53 AM   #7
My bad. That is what the receipt says. I think it is 1/4" and 1/8" thick. Just take a look at these pictures...
This is the one I have to bend: https://www.dropbox.com/s/b162j1zr3k...09.21.48.jpg?m
and
https://www.dropbox.com/s/fgvvusppjb...09.22.21.jpg?m
This is the one that I just need to open up a hole:
The label on the smaller one (one I have to bend) said 6" x 1-1/8".
The bigger one said 8" x 1-1/4"
Old 03-03-2013, 09:54 AM   #8
Oh! The measurements that are on the label are length and width, not thickness.
Old 03-03-2013, 10:00 AM   #9
Huge differance!
Got a vice?
Trying to drill the hole bigger without one can be dangerest. It's going to want to spin and catch.
I'd be using a step drill to drill out the hole.
Old 03-03-2013, 10:03 AM   #10
Arrange like this and hammer. You can also clamp on two additional legs to keep the legs straight.
Dorado is offline   Reply With Quote
Old 03-03-2013, 10:04 AM   #11
AHH, SPANS!!!
you will want to place the bracket against something that has an opposite 90 degree to the bracket where you can have the pressure down near the bend, say an inch up past the 90 bend in your bracket. then just start tapping with the hammer and the bracket should start to spread. use a 2x4 set up on it's side and set the bracket with the outer bend facing upward, the inner edges of the bracket should cross the edges of the 2x about an inch or so from the inner bend. tap down while keeping the bracket positioned in place and it should bend...
Old 03-03-2013, 11:07 AM   #12
Roofmaster
Rewards Points: 2,172
Put it in a vice and use a Ball Peen hammer. The best way to increase the size of a hole in relatively thin stock is a step drill, hands down. You can also use an end mill in a drill press. Most good vices have an anvil area on the back. Wear safety glasses.
I thought you had an L bracket from an Abrams tank turret for a minute there.
Old 03-03-2013, 11:31 AM   #13
Rewards Points: 220
yep = vice and hammer.
Old 03-03-2013, 11:52 AM   #14
He'd have to hammer at least an inch away from the bend and the legs of the bracket would be more likely to bend than with my method.
Old 03-03-2013, 12:27 PM   #15
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
do what joe caption mentioned.. if you modify it and something fails any engineers stamp will now be void
woodworkbykirk is offline   Reply With Quote
Tags
bend , bits , drill , metal , tools
Heavy Duty Casters BigJim General DIY Discussions 16 12-23-2011 05:48 PM
Heavy Duty Tools/For a Woman's Hands Sheila4467 General DIY Discussions 8 11-07-2009 03:30 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 08:50 PM
Heavy Duty Tapcons terri_and_jj Building & Construction 1 02-24-2008 02:25 PM
Heavy duty garage shelving suggestions feign3 Carpentry 1 09-20-2007 11:07 PM
