Old 08-22-2012, 10:13 AM   #1
How bad is it to have 1 cut stud on exterior wall
I was installing a new stove vent and noticed the previous guy cut the stud then didn't even vent it outside!!
I had planned on just using the space already created and cutting through the brick but was wondering how big of issue this is.
It's 1 - 2x6 - with a 6 inch section gone. Master bedroom above. House is 12 years old - no noticeable sag from the initial cut.
Appreciate and thoughts and feed back
Addman123 is offline   Reply With Quote
Old 08-22-2012, 10:27 AM   #2
Need a picture.
Old 08-22-2012, 10:28 AM   #3
It should have been headed off.
Old 08-22-2012, 10:32 AM   #4
Noticeable is the key term. Post a few photos of what you are describing
hammerlane is offline   Reply With Quote
Old 08-22-2012, 11:25 AM   #5
**** i already have the mircrowave on there
Old 08-22-2012, 11:31 AM   #6
is 1 cut 2x6 on an exterior wall going to create serious structural issues? I guess that is really hard to say....FOOK
Old 08-22-2012, 12:30 PM   #7
I have no idea what relevance this has. Unless you are trying to compare the weight of a microvave to the weight being transfrred down from upstairs??
Old 08-22-2012, 04:56 PM   #8
I think he is saying he mounted the microwave and cant take the pic.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-22-2012, 05:04 PM   #9
bbo
to properly address the situation, you should have a header constructed. micro out, header in, micro back in.
I don't think any of the people would endorse leaving as is on a load bearing wall no matter if there is currently sag or not.
bbo is offline   Reply With Quote
Replace a stud with electric wire through it jb721 Remodeling 6 09-23-2012 09:16 AM
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 07:48 AM
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 01:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
Is it safe to remove this stud? lofar Remodeling 4 06-17-2009 12:22 AM
