How To Attatch 2x4 To Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 01:40 PM   #1
How to Attatch 2x4 to Floor Joist
I've got a bouncy living room floor (2x8x14'6" floor joists on 1' centers). Among other things (blocking, sistering joists, etc) one of the things I want to do is attach 2x4s to the underside of the existing joists to effectively converting the joists to up-side-down T beams.
The question is how to attach the 2x4 to the joists such that I can safely support future loads on them (such as sheet-rock ceiling and framing for soffits to hide air ducts)?
HooKooDooKu is offline   Reply With Quote
Old 01-07-2010, 03:21 PM   #2
jlhaslip's Avatar
Rewards Points: 2,206
sister the existing joists with another 2 x 8 would be stiffer (imho) than adding the 2x4 as an inverted 't'. also, you are missing the top chord so it might not work as effectively.
jlhaslip is offline   Reply With Quote
Old 01-07-2010, 03:55 PM   #3
I have already sistered every third joist with another 2x10.
For weight and cost reasons, I don't want to sister EVERY joist.
Creating the inverted 't' is just a way to add a little more strenght for relatively little more weight.
