How To Attach Vapor Barrier To Crawl Space Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 10:24 AM   #1
Rewards Points: 51
how to attach vapor barrier to crawl space wall
I am looking for suggestions of what kind of sealent or caulk to use I see alot of websites saying furring strips but I dont really want to do that
joelowrider is offline   Reply With Quote
Old 02-27-2012, 11:02 AM   #2
Rewards Points: 13,994
http://www.crawlspacedehumidifiers.c...ur-crawlspace/
Old 02-27-2012, 01:57 PM   #3
Rewards Points: 51
That really did not awnser the question anyone else know od a product that will stick to both poly and concrete block?
Old 02-27-2012, 02:17 PM   #4
if you click on the "click to zoom circle it shows the vapor barrier being stuck to the block with construction adhesive.
http://www.crawlspacedehumidifiers.c...ectionview.gif
Old 03-03-2012, 08:20 AM   #5
Polyurethane Caulk is what I've seen. I don't have a specific brand to recommend.
Honestly, find some places online that sell items for crawl spaces like crawlspacevaporbarrier.net, and look at what they sell for attaching poly to walls.
CrawlSpaceMoist is offline   Reply With Quote
Old 03-03-2012, 12:05 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
accoustical sealant is the correct caulking to use..
its the industry standard expected by inspectors and about 1/2 the price of a tube of construction adhesive
woodworkbykirk is offline   Reply With Quote
Old 03-03-2012, 12:53 PM   #7
Rewards Points: 1,092
Originally Posted by woodworkbykirk View Post
accoustical sealant...
Tremco brand is popular here. Some folks refer to it as "black death" because it sticks to anything, including you. I stuck together some visqueen and pulled it apart over a year later; very hard to pull it apart, and the caulk seemed to shear more than it lost its grip on the poly.
Old 03-03-2012, 12:59 PM   #8
Structural Engineer
Vapor barriers are installed on crawlspace floors to reduce water vapor from migrating from the earthen floor into the crawlspace.
Rigid insulation is normally installed on the interior face of the crawlspace walls to reduce heat loss.
The surface area of the crawlspace walls is small compared to the area of the floor, so the floor is where you get the most effective use of the vapor barrier. And the amount of water vapor coming through the ground is larger than that which migrates through the crawlspace wall.
That being said, if I were going to install a poly-vinyl vapor barrier on my crawlspace wall, I would use stainless steel staples and staple it to the wood plate on the top of the crawlspace wall and let the free end extend to the crawlspace floor and extend inward on the ground for a foot.
House Engineer is offline   Reply With Quote
Conditioned Crawl Space - Advice re Waterproofing AND Int or ext insulation JohnNe Building & Construction 4 02-10-2012 06:53 AM
Air Barrier in crawl space biglurr54 Insulation 6 01-15-2012 08:50 AM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
crawl space and moisture Jeremy Hillary Boob, PhD Building & Construction 5 11-27-2008 08:13 PM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
