-   -   How to attach trim near the ceiling? (http://www.diychatroom.com/f19/how-attach-trim-near-ceiling-174161/)
TrailerParadise 03-11-2013 09:16 AM
2 Attachment(s)
We are very close (maybe four days) away from finishing the kitchen. All that is left is cabinets, trim, plumbing, and flooring. I suggested to go buy the wood to finish the cabinets, and my mom said we need to do the trim first, where the paneling meets the ceiling. Okay, im cool with that. Probably easier than bending over a cabinet to do it later. My question is how the hell do i attach the trim?
My kitchen is framed with 2x4's, 16" OC. There is a 2x4 at the top of the wall, with what looks like (i could be wrong) a piece of 1/2" plywood on the top of that. Above the plywood is the rafters. Paneling nails are not long enough to reach the plywood thing, but the trim is not wide enough to be nailed into the 2x4. Paneling nails are not long enough to hit the rafters either. Using longer nails means a bigger head and therefore easily visible. The trim is about a inch tall, and concave-shaped in the front.
How do i do this? Would construction glue work?
Ceiling is made of textured hardboard, wall is made of masonite board paneling. Attached a pic.
joecaption 03-11-2013 09:30 AM
Finish nails are used on trim.
Buy, borrow, rent a trim gun. 100 Times easyer and faster then by hand.
TrailerParadise 03-11-2013 09:44 AM
i dont have that option. We dont have the power hooked up yet, so whatever we use has to be cordless.
DannyT 03-11-2013 10:49 AM
then rent a cordless trim gun
Seattle2k 03-11-2013 03:32 PM
So...basically everything. You're probably going to want some countertops at some point too. :wink:
TrailerParadise 03-11-2013 03:39 PM
Countertops go with the cabinets. and no, its not everything, the hardest part of any of it was the walls. Once walls and electric are in the rest is a piece of cake. Took us dang near a month to get the insulation and wiring done
jagans 03-11-2013 04:18 PM
Did you install blocking into which you can nail? Did you ever put the new roof on?
