How To Attach Studs To Concrete Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 10:53 AM   #1
how to attach studs to concrete floor
building a wall in basement need some tips on attaching studs to concrete floor
debi55 is offline   Reply With Quote
Old 06-03-2009, 11:26 AM   #2
Rewards Points: 5,336
You can screw in the pressure treated bottom plate with tapcon screws or you can shoot them in the a gun.
Ron
Old 06-03-2009, 11:28 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Attach the bottom wall plate to the concrete floor with either Tapcon masonry screws or wedge anchors. Then nail the studs to the plate. The bottom plate must be made of pressure treated lumber or be isolated from the concrete so that it cannot absorb any moisture.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
stadry (08-16-2014)
Old 06-03-2009, 11:32 AM   #4
Old School
Willie T's Avatar
The Tapcon route will likely be the most readily available for a DIY homeowner. You can buy the whole set, screws, drill bit, and driver tip at H/D, Lowes, or just about any hardware store. Easy to use.
Sometimes all the necessary items come in one sealed plastic package.
Willie T
Old 06-03-2009, 11:57 AM   #5
Civil Engineer
Rewards Points: 4,954
Tapcons are fine, but I don't like all the drilling etc. For my money, a 22 or 38 Ramset works great, you can rent one at the U-Rent store. With proper selection of the nail, you can shoot right through the bottom plate into the concrete, and you get a good connection. Make sure you have hearing protection when you use the gun, it can be extremely loud.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Gymschu (08-22-2014)
Old 08-15-2014, 10:10 PM   #6
Thanks for the HELP. Wife has to buy dinner.
spinner1962 is offline   Reply With Quote
Old 08-16-2014, 03:13 PM   #7
Rewards Points: 4,806
some time ago someone posted a tip which we've since used,,, drill a hole thru the btm plate onto the conc floor,,, using a masonary bit & hammer drill, finish the hole into the floor,,, drive 2 16p nails into the hole thru the sole plate - fast, cheap, & holds terrific,,, we also like ramsets - they're faster
The Following 2 Users Say Thank You to stadry For This Useful Post:
Californiadecks (03-02-2015), MTN REMODEL LLC (08-16-2014)
Old 08-16-2014, 03:22 PM   #8
Rewards Points: 2,832
Seems to me this depends on the size of the hole drilled, A 1/4 inch hole maybe, anything larger than a 1/2 inch hole. no way.
ED
de-nagorg is online now   Reply With Quote
Old 08-18-2014, 09:35 PM   #9
Rewards Points: 43
I used the Ramset hammer shot .22 tool for my basement. Home Depot sells the tool for about $25 and they sell the nails and bullets. The floor is 50 year old 4" concrete and it worked great. Just be sure to wear eye and especially hearing protection!
jobblyman is offline   Reply With Quote
Old 08-19-2014, 02:21 PM   #10
Rewards Points: 3,834
Ramset gets my vote.
Canarywood1 is offline   Reply With Quote
Old 08-22-2014, 07:09 PM   #11
Rewards Points: 1,772
Ramset hammer shot .22 tool from Home Depot; quick, works, and fun!
I can't imagine drilling a zillion holes, hitting aggregate, snapping Tapcons, etc...and worse, the time element. Much faster to fire than drill.
bob22 is offline   Reply With Quote
Old 03-01-2015, 08:52 PM   #12
Rewards Points: 31
How far apart do the fasteners need to be when using the Ramset?
ccleme11 is offline   Reply With Quote
Old 03-01-2015, 10:52 PM   #13
For myself . No farther than 2 feet apart.
Depends on how sturdy you want it, If you are going to have a few rambunctious juveniles in there bouncing off the walls probably closer, but if it's grandma's sewing room, that is fine.
The ramset should come with an operators manual, look there.
Get yourself GOOD hearing protection, I have a lot of hearing loss from just such tools as a ramset, plus others.
ED
Old 03-02-2015, 12:55 AM   #14
General contractor/carpen
Californiadecks's Avatar
Rewards Points: 358
I like to go every other Bay, and one on any end, such as near a door way or corner.
Californiadecks is offline   Reply With Quote
The Following User Says Thank You to Californiadecks For This Useful Post:
kwikfishron (03-02-2015)
Old 03-02-2015, 07:21 AM   #15
Rewards Points: 960
I don't know if this applies to you, but power nails I bought from homedepot rusted and failed quickly on a block foundation wall. This wall has effloresent on the bottom fourths, but the failure was on top half. Not tapcons.
carpdad is offline   Reply With Quote
concrete floor question hbennett General DIY Discussions 1 05-18-2009 07:37 PM
Tile over basement concrete floor? BowDown Flooring 2 05-08-2009 08:41 AM
Pedestal sink - alternative to anchoring to concrete floor? aktheda Plumbing 2 03-19-2008 01:12 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
