How To Attach Pergola To THIS House? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 11:26 AM   #1
how to attach pergola to THIS house?
I would like to build a cedar pergola attached to this house. It will not have a roof. Because of the position of the windows and roof line, attaching beams to a ledger board does not seem possible, unless I cut the ledger? Alternatively, can I use masonry joist hangars? I do not want to place posts next to the house.
marym is offline   Reply With Quote
Old 02-03-2011, 12:22 PM   #2
Rewards Points: 5,336
You can't hang joists off of a veneer brick.
I'm thinking, no posts means no pergola.
Ron
Old 02-03-2011, 12:39 PM   #3
Thanks for your quick response. Actually, the house is solid masonry.
Old 02-03-2011, 07:16 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Two pilasters attached tot he house with knee braces connecting that side of the arbor.
That way you do not have the two "posts" next to the house, they are connected to house.
Only way I can think of.
Andy.
AndyGump is online now   Reply With Quote
Old 02-03-2011, 07:37 PM   #5
What is your definition of, "solid masonary"?
I don't see it from here.
Ron
Old 02-04-2011, 09:24 AM   #6
Ron
"Solid masonry construction is also called ‘Solid Brick’, ‘Double Brick’, and sometimes ‘Brick and Block’. In its most common form, a solid masonry wall consists of an outer layer of brick and an inner layer of brick (a layer of brick is called a ‘wythe’ in masonry circles).
The reason why solid masonry is a more accurate description than solid brick or double brick is because the inner wythe may not be brick. Because the inner wythe will never be seen, concrete or cinder block is sometimes substituted for brick.
Structurally, solid masonry walls are very strong and can, if properly maintained, provide hundreds of years of service."
Old 02-04-2011, 10:00 AM   #7
Andy.
On a previous thread: Pergola ledger board question
Originally Posted by BuiltByMAC View Post
(3) 6x6 posts, 1' tall - bolt 'em to the house framing (predrill everything to prevent any splitting of the wood), put decorative end cuts on them to pretty 'em up. Make sure you hit the house framing and not just the siding w/ your bolts/lag screws.
Screw (lag or Simpson SDS) your 2x6s to the sides of the 6x6 posts (again, predrill everything).
Viola - no ledger board.
Mac
Would this work in my case?
Old 02-04-2011, 10:59 AM   #8
rditz's Avatar
so if it doesn't have a roof, doesn't that simply make it a deck??
Also, are you going to be covering the windows?? or building out around them so you still get light??
I would bolt a ledger to the house, but not cover the windows. you can further support the ledger by vertical supports also bolted to the house. using joist hangers on the ledgers. build a suitable window well opening to provide access and light to the windows.
just my $0.02
rod
rditz is offline   Reply With Quote
Old 02-04-2011, 11:05 AM   #9
AndyGump's Avatar
Rewards Points: 660
I think that a ledger would look too intrusive and it would be cut at the window openings. I just think that would not look good at all, it would be very strong but not very attractive.
Pilasters would be the ticket though.
Andy.
Old 02-04-2011, 11:11 AM   #10
rditz's Avatar
Andy.
I see now... I googles Pilaster (never knew what they were called).. I get it... I was thinking more of the underlying structure...
sorry
Old 02-04-2011, 11:24 AM   #11
AndyGump's Avatar
Rewards Points: 660
No worries and no reason to say sorry. I have seen some of your other posts and for not being a professional in the business you are a really knowledgeable guy.
I learn stuff here all the time too especially from WRB.
Andy.
Old 02-04-2011, 11:34 AM   #12
rditz's Avatar
Thanks Andy... It tool me a long time to start to attempt my own stuff... I like to build things that are strong and will last. I try to re-use interesting materials like barn boards to make trim, stairs, etc..
I think we can all learn something and only get better because of it..
take care.
rod
The Following User Says Thank You to rditz For This Useful Post:
AndyGump (02-04-2011)
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 09:46 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
