How Attach New Basement Foundation To The Existing One? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 09:55 AM   #1
How attach new basement foundation to the existing one?
Hello, does anybody knows how to attach new basement foundation to the existing one by Ontario buidling code?
We are going to build an addition to our house, i mean my husband is going to build it, but he doesn't know how to attach both together.
The existing one is poured concrete, and the new one will be from cement blocks, the hight is 7'.
thank you very much.
elena is offline   Reply With Quote
Old 09-17-2010, 11:07 AM   #2
Rewards Points: 558
You attach them with 15mm re-bars. Go to your local city hall and ask if they have any sample sheets on your situation. I hope you are drawing up plans for this? If you are then your architect or structural engineer would have a detail on how this would be attached.
epson is offline   Reply With Quote
Old 09-17-2010, 11:19 AM   #3
i made all the plans myself, city didn't mind it, but we needed structural engineer and we finally found one, but she is asking us how we are going to do it ...!
i am going to email city planner now
thank you!
Old 09-17-2010, 02:02 PM   #4
Registered User
Rewards Points: 5,514
Some of your current guild-lines: http://www.hpo.bc.ca/PDF/BuilderInsight/BI2.pdf
http://web2.gov.mb.ca/laws/regs/pdf/b093-127.06.pdf
Just a quick search, maybe it will help a little with the rest of the addition…
Gary
Old 09-17-2010, 07:29 PM   #5
thank you , Gary,
will read it today
Old 09-17-2010, 10:22 PM   #6
Civil Engineer
Rewards Points: 4,774
Your structural engineer is asking you how you plan to attach the new foundation to the old one? Normally they would provide a detail for you.
My house consists of an old house (1959) with a full basement, and an addition (1976) also with a full basement. Both foundations are concrete. The two are NOT tied together, there is a construction joint between the two foundations. It is not required to tie the two together where I live (Massachusetts), and in fact there are some very good reasons not to tie the structures together. For one, if there is differential movement and the two are not tied, they will move independently, which can avoid a lot of cracking. If you do tie the two structures together, it is important to have a good, ductile detail, else you can get cracking at the junction point if the two structures settle differently, which is common.
Daniel Holzman is online now   Reply With Quote
Old 09-17-2010, 10:46 PM   #7
yes, she is asking how we plan to attach it...
it was so hard to find an engineer who can do something within few weeks...
anyway, thank you for reply
i feel completely lost now...
does anybody knows where i can read canadian building code? maybe we can do that joint too...?
Old 09-17-2010, 11:05 PM   #8
Rewards Points: 558
You would have to buy the book. Here is a link on where to get it: http://www.ontario.ca/en/faq/qanda/000695
Old 09-17-2010, 11:31 PM   #9
Registered User
I've found most of the U.S IRC online through one source or another. Have you tried searching for yours? This will get you started.... http://www.hastingshighlands.ca/uplo...ode%202007.pdf
And explore these: http://www.google.com/search?client=...32b8af52b7e0b8
Gary
Old 09-18-2010, 08:52 AM   #10
i found Ontario building code
http://www.markham.ca/NR/rdonlyres/A...deAct_1992.pdf
Old 09-18-2010, 05:01 PM   #11
Registered User
Good job!
Now find the up-dates that pertain to your specific question by the code numbers. First find the year Code you are under with local B.D. or equivalent.
Gary
Old 09-18-2010, 05:06 PM   #12
Gary,
we went to the library and they gave us the Code.
It's actually different from what i found on previous link and very easy to find information.
I liked it. Tomorrow we are going again. step by step ...
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 10:17 PM
Replacing old steel basement windows in a poured foundation? bergmw1 General DIY Discussions 3 03-08-2009 05:16 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
