How To Attach Ledger With No Rim Joist - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 09:56 AM   #16
Tool Cop
Originally Posted by kwikfishron View Post
Doesnt that look just lovely.
It looks like to me the only purpose of the rock between the joist is to plug the hole.
Id get rid of enough of the rock so you can block in between the joist, then continue the sheathing down to the bottom of the plate. Then you can lag a ledger to go through the sheathing into the blocks.
Be sure to get some tar paper or ice and water shield over the sheathing before you install the ledger.
Agreed... you definitely want to make sure to get a watershield over the sheathing.
TrafficCopSmith is offline   Reply With Quote
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 06:29 PM
How do I attach a ledger (for a 2nd story deck) if there is no rim joist? jrdamien Building & Construction 11 08-05-2009 06:25 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 12:41 PM
