How To Attach Ledger With No Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 04:15 PM   #1
How to attach ledger with no rim joist
I'm replacing my front porch. The floor joists (perpendicular to foundation wall) extend all the way out to the edge of the stone foundation with no rim joist. Some of the joist cavities are filled with stone/mortar, others with wood (yes I have bug, mice, bat and squirrel problems). The old porch was attached to a ledger that was just nailed to the ends of the joists. The old ledger was partially rotten, so I removed it. How do I attach a new ledger? Can I lag bolt it to the joist ends and the sill plate? I know this isn't a good idea, but what other options do I have?
degnem is offline   Reply With Quote
Old 06-10-2010, 05:20 PM   #2
kwikfishron's Avatar
Rewards Points: 186
You don’t want to lag into the ends of the joist.
Can you post some pictures?
kwikfishron is online now   Reply With Quote
Old 06-10-2010, 05:52 PM   #3
Some pics.
How to attach ledger with no rim joist-0610001648.jpg   How to attach ledger with no rim joist-0610001648a.jpg
Old 06-10-2010, 06:05 PM   #4
Rewards Points: 186
Doesn’t that look just lovely.
It looks like to me the only purpose of the rock between the joist is to plug the hole.
I’d get rid of enough of the rock so you can block in between the joist, then continue the sheathing down to the bottom of the plate. Then you can lag a ledger to go through the sheathing into the blocks.
Be sure to get some tar paper or ice and water shield over the sheathing before you install the ledger.
The Following User Says Thank You to kwikfishron For This Useful Post:
Clutchcargo (06-03-2013)
Old 06-10-2010, 06:09 PM   #5
Thanks. Lovely, I know. How should I attach the blocking so that it is strong enough to lag to? Also, do I really need to sheath it too?
Old 06-10-2010, 06:14 PM   #6
Rewards Points: 186
Yes, your set up perfectly to sheet over all of it. The sheathing is what will hold it all together and give it strength.
What is the decking going to be?
Old 06-10-2010, 06:20 PM   #7
4 inch PT T&G. I've thought about Fir or So. Yellow Pine, but I thought PT might hold up better. How should I attach the blocking?
Old 06-10-2010, 06:33 PM   #8
Rewards Points: 186
Id use galvanized or deck screws. It would be easier than trying to hand nail the blocks.
Id also use 1 - 1 ” screws on the sheathing unless you have nail guns.
If your using T&G for the top be sure to install flashing that goes up behind the siding and over the decking to keep the water away from the ledger so your not repeating this in a couple years.
Old 06-10-2010, 06:39 PM   #9
Thanks! Does the flashing necessarily have to go over the flooring? Could a Z shaped flashing be used... under the siding but over the ledger?
Old 06-10-2010, 06:51 PM   #10
Rewards Points: 186
Z over the ledger is what you would typically do but when you said a T&G decking on the porch, I just didn’t want to see water collecting and standing in that corner.
Doing both would be better yet, as long as the wall side of the flashings go up behind the siding.
degnem (06-10-2010)
Old 06-11-2010, 12:55 PM   #11
The plan...
Remove the stone and mortar from the joist bays.
Screw (or nail?) in blocking.
Replace the bottom course of sheathing.
Apply Ice and Water shield.
Lag a 2x8 ledger to the sheathing and blocking.
Z-Flash behind siding and over ledger.
Hang porch joists from there.
After more thought... I'm starting to wonder if this process will provide a strong enough base to lag to. Can someone reassure me?
Old 06-11-2010, 01:10 PM   #12
Rewards Points: 186
Originally Posted by degnem View Post
The plan...
Sounds like a good plan to me.
Try to get the flashing behind the building paper of the siding.
Old 06-11-2010, 01:18 PM   #13
Rewards Points: 186
You can always block with 4x.
The point of the blocking in your case is so the load of the lags transfers to the blocks and down the plate and that wonderful foundation of yours.
Old 06-11-2010, 02:11 PM   #14
4x8s? Yikes! That could get costly and be no fun to cut. I'll stick with 2x.
Call me stupid... but how should I attach the blocking? Toe nail to joists? To Sill Plate? Both? And would you still suggest screws if I have a framing nailer?
Old 06-11-2010, 02:44 PM   #15
Rewards Points: 186
You can nail them, the only reason I suggested screws is because its sometimes easier to do your precision toe nailing/screwing done without knocking the blocks in to far or splitting them out.
I wouldn’t build a house with screws but sometimes on little stuff like your doing, it’s just cleaner.
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
How do I attach a ledger (for a 2nd story deck) if there is no rim joist? jrdamien Building & Construction 11 08-05-2009 07:25 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 01:41 PM
