How To Attach Glass Tiles To A Mirror? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 08:19 PM   #1
How to attach glass tiles to a mirror?
What kind of adhesive would you recommend I use to attach small 1" square tiles on a mesh to a mirror? I am trying to make a frame of tiles around a mirror on the wall in my bathroom. Thanks!
Jales is offline   Reply With Quote
Old 11-12-2010, 08:22 PM   #2
Rewards Points: 5,326
I dab of clear silicone caulk on each tile would work.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Jales (11-18-2010)
Old 11-13-2010, 02:35 AM   #3
My recommendation depends on how many tiles are involved. If you have few enough that a dab of something on the back is not too tedious. That would be fine. However I would recommend construction adhesive over over silicone. It will have better holding power. I often use PL polyurethane construction adhesive.
If there are going to be too many tile to dab the back of each, I would mask the portion of the mirror that will remain visible and spread tile mastic with a 1/4" plastic V notch applicator.
I hope this helps.
Jesse
Portlandtrades is offline   Reply With Quote
The Following User Says Thank You to Portlandtrades For This Useful Post:
Jales (11-18-2010)
glass tiles over kerdi (thinset question) Queso Bandit Remodeling 12 05-15-2012 04:08 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Do i need to change the glass tiles? EmmaZhao Interior Decorating 6 09-22-2009 09:37 AM
glass tiles over kerdi (thinset question) Queso Bandit Tiling, ceramics, marble 1 04-17-2009 01:39 PM
