Old 10-10-2012, 12:34 AM   #1
How to attach a framed wall to radiant heated floor?
I'm planning to finish the basement. How do I attach the base of the wall to the concrete floor? Could I just use Liquid Nails?
kipper16 is offline   Reply With Quote
Old 10-10-2012, 12:37 AM   #2
PL premium for concrete is my choice. Unless you know exactly where the lines are do not use any nails/screws or such.
mae-ling is online now   Reply With Quote
Old 10-10-2012, 07:59 AM   #3
AHH, SPANS!!!
Ramset nailer,or tap con screws, and some construction glue. if you use glue correctly you can get by with less floor fasteners but you still need fasteners in case the glue ever fails from moisture or what not...
hand drive is offline   Reply With Quote
Old 10-10-2012, 08:08 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I wouldn't suggest that with any form of radiant floor (with hot water lines or electrical heat).
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
mae-ling (10-10-2012)
Old 10-10-2012, 09:54 AM   #5
Just my curious mind inquiring, are the radiant heats pipes UNDER the poured concrete, or IN the poured concrete?
In theory, how far down from the surface should the pipes be?
B
Beepster is offline   Reply With Quote
Old 10-10-2012, 09:58 AM   #6
Most often I find them in, not under.
I would use the PL and at the bottom of the wall. I install some short pressure treated 2 X 4's from the stud to the concrete wall so if the wall gets bumped it does not move back.
Old 10-10-2012, 08:56 PM   #7
AHH, SPANS!!!
I misread about the radiant heating part. adhesive only for sure...
Old 10-10-2012, 09:50 PM   #8
Thread killer
B
They should be in the middle of the pad but unless you get the concrete guys to pull them up when they pour, they quite often end up near the bottom
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 10-10-2012, 11:06 PM   #9
Thanks for the help.
Installing Radiant Floor Without Access to Floor Joists? aberrant HVAC 3 02-15-2012 09:18 PM
Radiant Floor Heat Mat algee Flooring 3 01-27-2011 10:02 AM
Structural questions WillK Building & Construction 6 01-13-2011 09:10 AM
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 01:59 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
